Boot error - requires control alt delete to recover
When booting computer screen says press control, alt, delete to recover. When press control, alt, delete it reboots and comes back to this screen. Is this a hard drive issue or something else?
Bootconfig might be bad for windows not to start. Or could be a hard drive problem. Windows startup repair might work or you might have to reinstall the operating system. If this does not work then possible the hard drive has problems.
Posted on Nov 27, 2012
  • 148 Answers
SOURCE: computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Posted on Dec 11, 2008
  • 253 Answers
SOURCE: error 0xd000000d restore failed
then u will have to format your c drive and then boot it again and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
  • 83 Answers
SOURCE: compressed hrd drive now it won't boot up error
boot from Windows 7 disc, and Repair Windows 7. When it comes up it will ask u the language, pick your language, then in the bottom left corner of that box that says Install now, you will find repair my computer :)
Posted on Apr 14, 2010
  • 130 Answers
SOURCE: wont boot up error msg:
...to reboot your computer. I am really sorry, but that means that your windows wont start because root folder is corrupted/damaged. On HP machines usually f10 is restore button. If not that one try f8.Reboot your computer and start tapping f10 till you see restore options. Then have your choice.Good luck!
Posted on Nov 16, 2010
Adam antony
  • 23 Answers
SOURCE: Machine will not boot.. Black
In this case you need to repair your OS. You need to insert the OS which is a bootable disk, in case of net book you need to connect a USB with OS loaded in it and select boot from USB in bios, for entering in bios you need to press the F 2 button while restarting the computer.
Posted on Jun 10, 2011
CD Drive will not allow boot
Change the boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 03, 2013 | Computers & Internet
Getting error nvidia boot agent 249.0542
It seems the Basic Input Output System (BIOS) settings have been changed on this computer.
This type of error message occurs when the computer is trying to seek a network device to boot from, or is set to boot from a removable disc or other media that have bootable files stored on them that the BIOS requires prompting or selection for in order to proceed to the boot stage.
First check that there is no disc in the Optical (CD/DVD) Drive -> if there is remove it -> restart the computer by pressing and holding down the Control (Ctrl) and Alternate Value (Alt) keys 2 fingers of your left hand -> press the Delete (Del) key with your right hand -> release all 3 keys -> tap either the Del or the Function 2 (F2) key 2-3 times as the first white writing appears on the black background of the screen after powering up -> the (Power On Self Test (POST) procedure will then redirect to BIOS Settings (often referred to as Setup) -> use the keyboard arrows to navigate to Set Default Values -> press the F10 key -> press y for yes or Enter for OK -> test the boot process again.
If the computer still does not boot properly repeat the above steps to enter the BIOS Settings/Setup again -> use the keyboard arrows to navigate to Boot Menu -> arrow down to Boot Device Order -> look at the BIOS Control Options at the bottom or side of the window to find the appropriate control keys for changing the order of the boot devices (often the + and - keys, the F5 and F6 keys, the Page Up [PgUp] or Page Down [PgDn] keys -> move/promote the Hard Disk Drive (HDD) to the First Boot Device position -> press F10 -> y for yes or press Enter for OK -> test the boot process again.
Nov 20, 2011 | Acer Computers & Internet
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
When I restart with the boot disk I made (or the intstallation disk) the computer starts up normally. I am not being prompted to scrub it. Help!
you need to change the boot order of the computer to boot from cd instead of hard drive.
When you first start up the computer you should see a message to press to enter setup the most common keys are:
  • Delete
  • F1
  • F2
  • F3
  • F5
  • F10
  • Escape
  • Insert
  • Control + Escape
  • Alt + Escape
  • Control + Alt + Escape
  • Control + Alt + Enter
Once you've entered setup you should be able to find a selection something to the effect of boot order chage the fist boot selection or primary boot device to the CD rom so that the computer will boot from the boot disk instead of the hard drive
Apr 19, 2011 | Iolo Technologies DriveScrubber
How do i reset my security code?
what security code??if you are refering to change your security password
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
Hope this helps
Mar 30, 2011 | Computers & Internet
Hi, I need to access the BIOS to boot from CD pear. I pressed F12 and ESC, and Ctrl-F1, alt-F1. It does not work. How I can access the CD to recover the BOOT? Thanks, Nacho
Have you tried pressing DELETE? Press the delete button and it will direct you to BIOS. You can then change the boot sequence of your computer so that you can boot to the cd.
Thank you for using fixya,
CARLO
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 04, 2011 | Fujitsu AMILO M-6500 Notebook
Black screen, disc error, press control alt delete. f10 seem to change screens called bio set up utility
Please state the actual problem while booting your computer. This will help us to provide more accurate and precise solution.
Jan 05, 2011 | Computers & Internet
I have a Dell Latitude e5500. when booting the computer the Dell start up screen appears and then is replaced by a black screen with a blinking cursor. I have tried pressing control+alt+delete; this...
You have errors in the boot section, not allowing any of the GUI's to run.
When the system starts press F8 and when you get the menu select Recovery.
That will fix it.
Dec 19, 2010 | Dell Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
