Question about Whirlpool duet Washing Machines
How can fix f 02
F 02 SHOW
    Sergeant:
  • 198 Answers
Whirlpool duet f02 codeHow to fix fo2 fault code on a whirlpool duet front load washing machine, The whirlpool duet is one of the machines that have a main computer control that operate and monitor the functions of the machine,
This control is usually mounted behind the front panel,sometimes at the back or to the side, it also has a speed control board that is mounted on the bottom usually at the right side.
Whenever a problem accur there is a fault code displayed on the machine, there is a technician sheet with the fault codes on the machine, the technician can use this guide to go directly to the problem,
This f02 code mean there is a problem with the drain, there is a drain filter that sometimes get clogged with lint and other things,
Removing the kick plate and removing the drain access on the pump will reveal the drain filter, use a small bucket, and towels to catch the water that will be in the pump
Posted on Nov 27, 2012
I tried to get a sticker and failed because it stated that 2 (02)sensors, catalyst and evap were not ready on my 2001 saturn sw2. How do I fix this? I have been over 300 miles and have failed twice.w
It is not something you fix, the system self tests after any time the battery is disconnected or the system reset with a scanner tool. Drive it until it clears, take about 20 miles of mixed driving, idle time, freeway, moderate speeds like in town. Gas tank must be at least 3/4 full for the test to complete. This is known as an OBD2 drive cycle. If you had a check engine light and it comes on again then you did not fix the problem.
Mar 28, 2014 | 2000 Saturn SW2
How do you fix the camber on a 02 sable?
It takes a camber gauge to set the camber.
$260 is high for just setting up the front end, unless it includes parts.
Online Pep Boys show $89.99 + parts.
I'd let a professional do it.
Wheel Alignment
Feb 12, 2018 | 2002 Mercury Sable
Yahoo messenger wont show messages comeing in or going out
try it ! http://devicearea.com/2011/02/10/how-to-fix-yahoo-messenger-if-you-cant-see-what-are-you-typing/
Jan 22, 2011 | Yahoo Messenger
How do you fix a ps3 when you turn it on it dosen't show your users
Check out the problem and solution for #3
http://rescuetechla.blogspot.com/2009/02/five-most-common-ps3-problems.html
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
PGM-FI light came on- on dash and the car is running realy rough could you tell me what this is and if it is costly to fix?
get 02 sensors tested-they monitor rich n lean conditions--chec for any vacuum leaks-they dont show up on computors
Aug 06, 2010 | Honda Civic Cars & Trucks
Random disconnects
Your problem is on the Cable companies side, there is nothing you can do besides making them come out to fix it. Be warned that some ISPs are known to play the blame game and pin it all on you...I used to work for Comcast and seen this happen regularly.
In short, you are looking for a connection problem in the lines around/in your house.
The long version:
The cable wires that run around the neighborhood are the main lines. Every few houses there is what is called a "tap". The tap is a little box with a few ports to connect a regular sized cable to it(the same cable you see inside your house). Fromt he tap the cable goes to your house and "should" be connected to what is called a "ground block". A ground block should have a wire going from it to some type of ground. This is to prevent an electrical shock traveling through the lines into your house and frying anything connected to it. From the ground block it should then go into a "splitter". The splitter has 1 input port for a cable line to connect to and has anywhere from 2-10 output ports. If there are unused output ports, they should be capped off to reduce signal bleeding/loss/interference.
Okay, now the fun part. From the ground block, the next step in your line should be a 2 port splitter. So it should have a cable going into it and 2 coming out. One of the 2 coming out of it should be going "directly" to your modem. If the setup is any different than I just described, your house was wired wrong and could be the culprit to your internet problem.
There is also a possibility that your "tap" is bad, I have seen it more than a few times. A low level tech can fix this.
Also, there are boxes every so often on the main lines that run on the telephone lines. They can be misconfigured and also create internet problems. These will require a higher level technician to fix.
Next possibility is that your modem itself is bad, when you schedual a trouble shooting call with your ISP, ask them to bring an extra modem with them.
Almost forgot an important one, where the cable "screws" into any port on the tap, ground block, splitter or modem...it is not snug tight and you are not getting a full signal. This is a very very very common problem. The endings that screw into things, they are called "F-Connectors" and do periodically require to be replaced.
The tech that comes out to fix your problem, if they do not have a wave length meter on them...they do not have the proper tools to diagnose your problem. An official tech of your ISP will almost always have one on him, it is the contractors that usually do not. Ask for a real tech and not a contractor to show up.
Keep calling when you experience problems. Each time you call, ask for money to be taken off your bill for your troubles. If the person on the phone says they can not do that, ask for a supervisor.
Hope this helps.
Feb 02, 2010 | Arris SURFboard® SB5101 Cable Modem
How to fix my 2002 impala
#2 02 sensortrips the ligh, but is not necessarily the prblem that cause it to trip.Your emissions are too high and it could be running too rich or the cat cnverter is not efficient. The first 02 sensor constantly makes fuel adjustments so it too can be defective.
Nov 09, 2009 | Cars & Trucks
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I own a 02 Silverado 2500hd with a 8.1L. The
Have a fuel pressure test done on it, that will show if there is a fuel problem.
Jul 14, 2009 | 2005 Chevrolet Silverado
Oxygen sensor problem
Have you noticed any proformance issues? low numbers in the 02 indicate rich exaust, high is lean. If they are fixed or only change a small amount then you may have another condition causing it. Good Luck
May 25, 2009 | 1997 Pontiac Firebird
Washing Machines Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal De
