Question about LG Televison & Video
MY tv REMOTE DOES NOT WORK
I CHANGED THE BATTERY AND THE LIGHTS COME ON BUT NO ACTION TAKES PLACE. NOTHING HAPPENS
On my dish remote for tv 2 sat button stopped working and wont light up. all other buttons work. i have changed batteries but nothing changed. How do i fix this because i dont wan to waste money on an
Kevin rico,
I can definitely check this out with you. Does the SAT button light up when you press any buttons at all? If you press SAT, can you operate the receiver?
If neither of those work then the remote most likely needs to be replaced. If you would like to try that option, just send me an email at thomas.faust@dish.com and i'll assist you further!
Tommy Faust
DISH Social Media Representative
Jul 05, 2012 | DISH Network 142923 Remote Control
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
My remote doesn't seem to be working to my Naxa TV. I have put in new batteries. The TV comes on with the "green" light in front. But when I click remote "pOWER" nothing happens ??? Thanks
If you replaced the batteries and can turn on the TV manually, then the button is probably not making proper contact with the remote. Try opening up the remote and placing a small piece of tin foil where the power button is, close the remote up and it should work.
Aug 03, 2009 | Televison & Video
Akai KC02-E1 Remote with new batteries stopped working.
First, You cannot resync the remote, Second the IR sensor may be bad on the tv and third, the Digital bd may be bad. The IR sensor connects directly to the Digital bd which is the brains of the tv. Also, there maybe a stuck button on the remote or the buttons on the tv.
Jul 13, 2009 | Akai PT4298HD Rear Projection Television
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Remote not working
press the red button under the front door then press the button under the battery compartment of the remote.
good luck
please mark the post with a fixya
Feb 12, 2008 | Nintendo Wii Console
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Televison & Video Logo
16 people viewed this question
Computer Repairing
Computer Repairing
