Question about Refrigerators
Fridge keeps losing temperature - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 26, 2012
My daughter bought back a mini amana fridge it seems too hot on the sides and its on 6 os that normal??
Sorry but I don't recognise the fridge brand. The internet suggests these are not the things called mini fridges but in reality are merely coolers so I guess it is a regular fridge designed to keep stuff between 2 and five degrees C.
Not sure what you mean by 6 os.
Conventional fridge design has a thing at the back that looks like a radiator. This condenser is prone to corrosion and is easily damaged resulting in the loss of refrigerant. Since it was decided all types of refrigerant gas is damaging to our atmosphere, manufacturers have been increasingly burying the radiator thing in the fridge casing where it is protected, often at the sides. Usually the condenser will become quite hot until the fridge interior is down to the required temperature when just maintaining the inside temperature it will vary between warm and cold if the door isn't opened much and the insulation and door seal is in good condition.
Burying the condenser(s) in the casing makes them less efficient at losing heat and so they will become hotter than the conventional old-fashioned design during the interior cooling stage..
I hope this helps and little.
May 15, 2016 | Amana Refrigerators
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Aug 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Westinghouse fridge
cooler means coooler cabinet temperature...
Feb 12, 2008 | Refrigerators
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
