Question about Cub Cadet Hydro Pump Drive Assy, New, Pn 01006937p, Fits M48, M54, M60, M72 Tank
Shaft shaking on hydro gear pump
It is a cub cadet m48 tank and i have replaced the shaft seals and put it all back together now it seem like the shaft has alot of play in it
  • 40 Answers
SOURCE: forward rev shaft seal leaking on 1650 cub cadet
I would say no. your best off to take that in to shop services riding tractors.
Posted on Mar 11, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 109 Answers
SOURCE: hydro gear hand release valve doesnot alow you to
Check to make sure the brakes are not engaged
Posted on May 03, 2009
  • 138 Answers
SOURCE: Cub Cadet 129- The drive shaft from the engine to
This mis alignment of 1/4" is about normal that is how and why cub put the rubber flex coupling on the hydro... however if there is play in the hyro input shaft then we need to determine what the cause of this is. Good luck
Posted on Sep 07, 2009
Testimonial: "Thank you. Very prompt."
18funkra
  • 10 Answers
SOURCE: I have a cub cadet m48, It won't start. I replaced plugs and tested them on the wire, they have spark, and cleaned fuel filter and blew out the fuel lines to carb., what am I missing?
Maybe different oil or gas
Posted on Jun 07, 2012
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
May 21, 2015 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub cadet slt 1554 will not move when running
hydro pump has gone out replace it or hydro lever not engaged
Jun 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Adjust idle speed
on the top of the carburator there should be an adjustment to set the idle speed
Apr 25, 2013 | Cub Cadet Garden
Cannot engage the gears for RT tiller
I have spent time researching this as mine just did this. It seems you will need to take apart the gearbox and find the issue there, most say some part has bearings inside it that have no grease, and no way for grease to get in there...then it causes something else to break and get stuck.
Trying to decide whether I should try to fix it or take to service tech or ditch it all together.
Jan 30, 2013 | Cub Cadet Rt 65es Tiller 2011 Model
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
Cub Cadet 129- The drive shaft from the engine to the hydrostatic drive does not line up at the hydro end. What should I do? The roll pin in the shaft at the engine hub it connects to kept shearing, and...
Sep 07, 2009 | Cub Cadet Garden
Forward rev shaft seal leaking on 1650 cub cadet
Mar 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Hydro Pump Drive Assy, New, Pn 01006937p, Fits M48, M54, M60, M72 Tank Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
