Main oven element probably needs replacing, usualy they only last about 4-5 years depending on usage, fairly cheap to replace, around 15 pounds for the part, fairly easy job for diy enthusiast, or no more than 30 mins work for a appliance repair person. On most ovens, first isolate the oven for safety at the double pole switch outlet. open oven , remove all shelves etc, look for a metal cover at the back which covers the fan and element, usualy two or three screws on the cover to remove, behind cover you see the element and fan, remove two screws on the element mounting plate and carefully pull out with the wires, carefully pull off the two connectors on the element, connect new element and fit in reverse procedure of above.
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
SOURCE: Newhome 1000dfdl main fan oven appears to stay at
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element whilst the temperature light remains on.
but if the temperture light is off then its likely to be a faulty thermostat
SOURCE: Although the fan is rotating in the main oven the
Hello & Welcome to FixYa
This indicates oven temp failure and to check if that is bad then check the sensor for around 1100ohms, if it is more then that then it is the temperature sensor, if it tests fine then it is the electronic control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
