Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher upper spray arm not turniong
MOD. # GSD3400G00BB SER.# VG703554B Our GE Nautilus dishwasher upper spray arm is not turning. We disassembled it and checked for clogs & cleaned it. We also cleaned bottom filter. The lower spray arm is working fine. Any suggestions on what the problem may be?
  • Kerry Nov 28, 2012
    Hel[p!
SFroese
  • 141 Answers
SOURCE: GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Posted on Sep 06, 2008
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Cannot remove lower spray arm ge dishwasher GSD5911
Some spray arms out there are reverse threaded, however the one that you are dealing with should be regular threads. Should be an opening at the very bottom of the spray arm where you can stick a screwdriver through and use both hands(one on each end of screwdriver) and carefully loosen it. Make sure you get the new one on as tight as you can by hand, then check to make sure its tight by using the screwdriver again. With the screwdriver through the hole, and one hand on each end of it, just apply pressure clockwise, but you do not have to force it. Hand tight plus an ever so slight turn with the screwdriver should do it. Don't forget that anytime you are replacing the spray arm, you must always check once the new one is in place that you do not have a leak underneath the dishwasher. Also remove all water before you start replacing the spray arm to prevent water from leaking once you break the seal when loosening the spray arm.
Posted on Apr 04, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
SOURCE: Need to clean out the upper spray arm and so would like to remove it (like I did the lower one) and clean it out. Help!
We have a PDW7800J01WW that I removed all the arms on recently.
There is a single hex-head screw that acts as the pivot at the center of the top most arm. Just remove this screw to remove the spray arm.
Be very gentle reinstalling it though as it is easy to over torque it and strip the plastic hub it screws into.
Posted on May 15, 2009
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
GE nautilus DW. The top rack won't wash. Just the bottom works.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 22, 2011 | GE Nautilus 24" Built-in Dishwasher
HELLO MY GE Nautilus 24" Built-in Dishwasher sounds like it is working but there is no water spraying when the wASH cycle is iniciated any suggestions are appreciated
Hi, W/D here.
Check to see if the spray arms might be clogged. Look at each nozzle and slot. If you can remove them and clean over the sink. Back washing with the faucet, and opening the holes with a toothpick should free them up. That would be a good first step.
--Best regards--W/D--
Jan 26, 2011 | GE Nautilus 24" Built-in Dishwasher
THE WATER IS NOT SPRAYING. MIT COMES OUT OF THE SPINNING ARM, BUT NOT ENOUGH PRESSURE TO SPRAY.
the arm does not need much pressure to spin. but the arm stops spinning if a little pice of dirt is stuck inside or at the small holes. so best you can do is build out the arm and clean it, rinse it in reverse direction and get any dirt out.
Jun 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Mar 29, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus making noise
hi you have something in the sump there's a screen on the right side of the spray arm with 2 screws remove them and take screen off use your fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump.
I hope this helps...I believe it will....Good luck and good day....thank you for your rating my effort....The Fang.
Mar 23, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus GSD3400G00BB
The easy way to fix it would be to empty it and run a quick wash. hopefully the latch is just stuck and it will open up.
Please remember to rate me.
Feb 02, 2009 | GE 24 in. GSD3400G Built-in Dishwasher
Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher Problem
check water level is ok. check its heating. open door when in operation and check if spray arms are rotating. if not, take them out, run water into centre hole and check water comes out of jets. note the spray arms only rotate with water coming out of angled jets at end
Apr 19, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
334 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
