Question about Frigidaire FEB30T7FC Stainless Steel Electric Double Oven
Error code f15
My frigidaire feb30t7fc was cooking just fine but then error code f15 came up a the oven would not restart
4 Suggested Answers
SOURCE: F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Posted on Jun 01, 2009
  • 56 Answers
SOURCE: i have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
F43 error on Frigidaire Wall Ovn?
The code F43 means - The cooling fan speed, as read by the tachometer input of the EOC-display board, is abnormally too slow. when the cooker is on can you feel the fan is on through the upper vent? If not then the fan is the problem if you can then the fan sensor is the problem!
Oct 21, 2014 | Frigidaire PLEB30T8A Electric Double Oven
There s no power to my oven
Good Morning Friend,
I understand that you are not receiving power to your Frigidaire oven, model# FEB30T7FC, even though the power is on to your home and the breakers have not been tripped. Please try the following:
    1)Be sure the electrical cord is securely connected into the electrical junction box.
    2)There is a possibility that the service wiring is not complete.
    3)There is also a possibility that there is a short in the cord or plug. Replace the cord or plug.
    4)The house fuse has blown or the circuit breaker has tripped immediately following installation. The house fuse may not be fully engaged. Check the fuse and screw or engage circuit breaker securely.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FEB30T7FC Stainless Steel...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven beeps and show F1 and F3 while trying to cook or even 2hrs after cooking.
F1 code is a "EOC (Electronic Oven Control) failure" Replace your oven control
F3 code is a bad oven sensor the sensor should have a ohm reading of 1100 at room temp. Replace your oven sensor as well.
Dec 06, 2010 | Frigidaire 30" Built-In Single Electric...
I have a frigidaire model cfeb786jgb3 error
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
1992 Frigidaire built-in oven with F4 error
f4 is the code for a shorted oven probe try first replacing it
Feb 12, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire FEB30T7FC Stainless Steel Electric Double Oven Logo
327 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
