Question about Stanton STR8-80 Turntable
Stanton TONE ARM adjustment - Stanton STR8-80 Turntable
2 Suggested Answers
  • 189 Answers
SOURCE: I just recently bought a used stanton str8 80 but
HELLO
There is nothing more annoying than buying something second-hand to find parts are missing. I've had a look on the net for you and you could try these sites - they might be able to help.
www.HTFR.com and www.djdeals.com.
I wish you luck finding a weight and hope this has gone some way to helping!
Posted on Aug 05, 2009
Can a Stanton str8-80 tonearm be fitted to a Stanton str8-100?
I am looking at pictures of the both the STR8-80 and STR8-100 and the both have the straight tone arm. So when you say an "s" arm I am a bit confused. The main part of the STR8-80 is the same as the 100. However the 100 has a different base to it, with additional controls such as lock(?) on it.
Having said that here is a guy that has converted the 100 to an S arm with pictures!
http://www.vinylengine.com/turntable_forum/viewtopic.php?f=18&t=90443
Oct 16, 2016 | Stanton Audio Players & Recorders
Rewiring tone arm stanton st.150
Nice , i just received my tonearm wire for a technics. mk5
First question , Which tonearm are you try to put in and why, since if you want a better sound , sell the unit instead of useless replacements and do you use the phono or line out...
Feb 15, 2014 | Stanton Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Replace tonearm rest clip on Stanton STR8-80
the screw in under so you need the right tools
Jul 31, 2012 | Stanton STR8-80 Turntable
Convert 45s to mp3s - sound scratchy
Just check the connections to the cartridge on the Stanton. Make certain they fit and are correctly fitted. Also check or replace the stylus, if it is not new.
Jun 14, 2012 | Stanton T.92 USB Turntable
Stanton STR8-100 Turntable ground wire?
There is no such ground points in the Stanton STR8-100. The main thing you have to check is the RCA cable used. You should a high quality RCA cable suitable for Phono connections. If you use a normal RCA cable then it will produce HUM because if its weak ground shield.
Try with a good quality RCA cable with Good ground shielding.
Ajin
Apr 27, 2012 | Stanton STR8-100 Turntable
I just recently bought a used stanton str8 80 but it came without a tone arm weight?! where can i find a replacement?
HELLO
Aug 05, 2009 | Stanton STR8-80 Turntable
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Stanton STR8-80 Turntable Logo
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
