Question about Dryers
LG Tron Gas Dryer Model # DLG8388WM - I bought a used LG Tron and have to convert it to LP from Propane. What parts do I need and how do I do the install myself. Thank You.
When I turn the dryer on hooked up to the LP gas line it doesn't ignite and I get a gas smell. I hope this is due to the wrong gas line.
  • Dempster Boyd Nov 26, 2012
    Whoops! Convert it to Natural Gas.
  • C. Ray Gill Apr 09, 2013
    New natural gas oriface here,http://www.appliancepartspros.com/sectio... Part # M170, $5.57+ shipping. How to install it herehttp://www.appliancefactoryparts.com/con... true page 31, pdf page 32. Be sure to back the valve adjuster out as shown or sooty flame!
    New Friend:
  • 22 Answers
Here's the oriface to convert it to Natural gas:
http://www.appliancepartspros.com/section-3-parts-for-lg-dlg8388wm-abweeus.html
Part # M170 is for Natural gas, you have a #M171 in there now for Propane.
$5.57+ S&H
Here's the manual to do the conversion:
http://www.appliancefactoryparts.com/content/pdfs/125536.pdf
Real page 32, pdf page 32.
**** Be SURE you back the gas valve screw out as shown or soot city in your tube!!!
You can pay a service tech like myself $90/hr, 1 hour minimum charge to do the conversion in 5-10 minutes, or do it yourself in 10-15 minutes with a #2 philips screw driver, a straight slot screw driver and a crescent wrench. Your choice! :) Hope this helps you.
Posted on Apr 09, 2013
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is the part to order.
Posted on Nov 27, 2012
catriver
  • 878 Answers
SOURCE: LP gas conversion on an LG dryer
Mr. D, make sure you have a little time, you have to remove a few things. 1. Remove the 3 screws in back which hold the top on. Slide the top back and lift off. 2. Remove the two screws on each end of the control panel frame. (inside). Disconnect the control panel harness, pull up and foward, place aside. Remove the 4 screws on the top of the front cover, disconnect the harness for the door switch and it should pull foward. Now I believe you can get at the gas valve on the lower right. Make sure to reverse the limiter as well as putting on the new orfice. If you need any further help, e mail me at catriver1@gmail.com Will be home this evening. Catriver.
Posted on Mar 17, 2007
ngafm
  • 166 Answers
SOURCE: Natural GAs to Propane
Call Maytag or whirlpool!
Whirlpool makes Maytag now same company
They make a conversion kit!
ngafm at your service.
Please rate me before you sign out!
Posted on Sep 06, 2008
jyackle5
  • 8197 Answers
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Posted on Jan 19, 2009
  • 9 Answers
SOURCE: converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
Posted on May 25, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I have a DLG8388WM LG dryer i have changed the ignitor and the thermostat twice now it still will not stay lit.it lites then goes out within a second what else could it be.
It's common for a problem like this with a gas dryer to be cause by a bad coil on the gas valve.
This is often a simple and cheap repair, but I looked up you model number and I don't believe you can get a replacement coil on this model LG dryer so you would then need to replace the gas valve, part # 5221EL2002A
Aug 02, 2011 | LG DLG5932W Gas Dryer
I have a lg dryer DLG5988S is it natural gas or lp?
most of these dryers are factory set for natural gas and need to be converted to propane if using propane
Feb 09, 2011 | Dryers
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
REQUIREMENTS.
Jan 19, 2009 | Dryers
Converting LG gas dryer to propane DLE7177WM/DLG188WM
call your propane dealer and they should have someone to convert it to LP for you and yes that sounds to high / larry
Dec 01, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at http://us.lgservice.com/index_b2c.jsp
Nov 02, 2008 | Dryers
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
158 people viewed this question
Top Dryers Experts
