Question about Casio Calculator Graphing FX 9750GII Calculator
How do I find the gcf on the Casio FX 9750GII Calculator
I need to find out how to find the gcf on my calculator, Casio FX 9750GII Calculator. I will be taking a quiz tommorow and should I run across a problem that I am unable to do, I want to be able to answer it. I have looked through the manual and didnot find the answer. Please advise.
  • 86 Answers
SOURCE: Manual for the casio fx-260 solar fraction calculator
FX-260Solar User Manual
Posted on Feb 09, 2009
SOURCE: Reset?!
Thank You so very much, this solution fixed my problem.
Posted on Feb 13, 2009
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
  • 8073 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
  • 8073 Answers
SOURCE: PLEASE HOW DO I CHANGE MY CASIO FX-82MS
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below. Hope it helps.
Posted on Oct 11, 2009
How can I change the threshold for scientific notion rounding in normal display mode on my Casio fx-9750GII.
[PDF]fx-9860G Series_fx-9750GII_fx-7400GII_Software Ver. 2.0_Eng - CASIO
support.casio.com/pdf/004/fx-9860GII_Soft_E.pdfThe contents of this user's guide are subject to change without notice. ... For full details on availability in your area, contact your nearest CASIO ...... The calculator normally displays values up to 10 digits long. Values that exceed this limit are .... The fx-7400GII and fx-9750G II are not equipped with a Math input/output mode.
SOLVED: Scientific notation on the casio fx-9750GII - Fixya
www.fixya.com/support/t20210775-scientific_notation_casio_fx_9750gii
Sep 20, 2013 - Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below. Scientific notation on the casio fx-9750GII
Mar. 13, 2017
SOLVED: How do i turn off the scientific notation
Mar. 30, 2015
Using Scientific notation on the casio fx-9750GII
Oct. 5, 2013
Casio FX-9860G Graphic Calculator Scientific ...
Oct. 18, 2011
More results from www.fixya.com
How can I use scientific notation on casio calculator? ' Socratic
https://socratic.org > ... > Correct Use of a Scientific Notation on a Scientific Calculator 7 days ago - Most scientific calculators have a button EXP ...type in a number, press EXP , AND then you asked to input the exponent as a power of 10 .
videos
casio fx 9750gii scientific notation Google Search
Jun 18, 2018 | Casio Computers & Internet
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
Hoe to Calculate nPr and nCr on a Casio fx-9750GII?
In Run/Mat screen, press the OPTN key followed by F6, the F3:Prob. The nPr and nCr tab are accessible. Type n then the relevant tab, followed by the r-number.
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
Oct 16, 2012 | Casio Calculator Graphing FX 9750GII...
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
Jan 19, 2011 | Casio FX-9750GPlus Calculator
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
What is the better calculatorTI-83 Plus or FX-9750GII
If you have to restrict your selection to one or the other the Casio wins "hands tied behind its back". If you need convincing read on.
Advantages of Casio
Newer technology
About half the price
About twice the Ram
Uses iconic menus
Most screens have tab/menus: No need to scroll.
Conic graphic embedded in OS, not need for an extra application
Dynamic graphing embedded in OS, no need for an extra application
Has a reset button
Several types of statistical graphs that do not exit on TI83 (pie chart)
Ability to select the integration algorithm
Better screen resolution.
Jan 12, 2010 | Casio FX-9750GPlus Calculator
Casio Calculator Graphing FX 9750GII Calculator Logo
674 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
