Question about Panasonic Dmr-eh67e Pal Dvd Recorder With Hdd 250gb And Sd Slot
U99 error code
Cannot eject dvd; clock time is OK, no remote communication,...
    Problem Solver:
  • 17 Answers
The remote isnot going to eject the the disc, You have to press the eject button on the unit, To get the disc to eject,
Posted on Nov 27, 2012
  • Filijako Nov 29, 2012
    Nice try! Tnx.
    No one button on theVRC operates except the On/Off button. From time to time for some reason display changes the messages depending on the command from the remote unit. But nothing useful and repeatable. Could one save the data from the disk if connected to PC? .
DVD player won't eject and an u99 error code is displayed.
Hello
It is an internal circuit problem.
The unit fails to operate properly. Press [POWER] on the main unit to switch the unit to
standby. Now press [POWER] on the main unit again to turn the unit on.
OK
Jun 10, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
U99
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic Dmr-eh67e Pal Dvd Recorder With Hdd 250gb And Sd Slot Logo
64 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
