Question about Dell Dimension C521 PC Desktop
Cpu fan failure message when booting
When booting up my Dell Dimension C521 an error message pops up theat states "cpu fan failure" I immediately shut down in fear of damaging something.
Where can I buy a replacment fan? Dell is useless because it is out of warranty. I just want to replace the fan but am having a problem finding one to buy.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 49 Answers
Be sure to get the correct size if replacing only the fan. I tried finding one myself a couple months ago with no luck at the local electronic stores so replaced the heatsink/fan combination.
Here are some listed at Google Shopping to order online but my local Best Buy, Circuit City and other electronic stores did not have any.
http://www.google.com/products?sourceid=navclient&rlz=1T4GGLR_enUS207US207&q=cpu%20replacement%20fans&um=1&ie=UTF-8&sa=N&tab=wf
Posted on Jan 10, 2009
    Novelist:
    Scholar:
  • 72 Answers
The CPU fan and assembly is easy to replace, but proprietary. You will have to purchase from Dell.
Go to their spare parts purchase site here:
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&cs=19&l=en&s=dhs&redirect=1
You can download the service manual here:
http://support.dell.com/support/edocs/systems/dimc521/
Let me know if you have questions.
    President:
  • 1,179 Answers
Sad to say but this model dell uses a specific fan made for dell. Unless you want to modify your cpu cooling system you will need to contact dell for a system specific replacement part. Hope this helps.
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Diskette Drive Failure for Dimension C521
Most C521's have no floppy, if you have none:
boot to the BIOS, (F2 at boot) go to the drives setting, diskette (May be listed as floppy disk drive) set to NONE, exit and save settings
Apr 10, 2010 | Dell Dimension C521 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
I changed the CPU fan on Dell dimension 3000 but it does not run.
Dell uses a proprietary fan on it's cpu's. This is more than likely your problem. The motherboard does not recognize the new fan and the motherboard is not powering it on. Without replacing the motherboard you are stuck using dell replacement parts for this model. The motherboard & psu are also proprietary in this model so it would take a whole lot of modification to use anything but Dell replacement parts. Your pc is shutting down due to overheating. Sorry. Hope this helps.
Jul 12, 2009 | Dell Dimension 3000 PC Desktop
Alert chipset heat sink not detected system halted error message
It is NOT the CPU fan! There is a heatsink over the northbridge chipset adjacent to the CPU. The clip that supplies pressure to maintain contact between the northbridge and the heatsink has detached on one or both ends. There are wire loops at each end of the clip which feed into the motherboard. When the clip detaches (solder failure), it pops the loop out of the motherboard. The BIOS recognizes this condition as a heatsink failure, hence the error message.
Jul 10, 2009 | Dell Dimension 4600C PC Desktop
Not booting
listern to what ur beep codes say. one short-fine, one long & two short beeps-video failure, so on ... ... ...
May 02, 2009 | Dell Dimension C521 PC Desktop
Freezes during start up
My first plan of attack would check
Second the event log in the BIOS, looking for a heat event. Make sure your fans are spinning, while you are in there get a can of compressed air and blow out any and all dust. Sometime it becomes necessary to remove the processor and put a little Artic 5 between the cpu and the heat sync.I would check out the video card, the easiest thing to try first is to remove and update the video drivers. I still lean towards the heat event Idea...
Hope this give you a headstart in the correct direction. Good luck,
PS, if you are the one shutting it down and rebooting, look to the Video Card,
Apr 25, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Dell Dimension C521 PC Desktop Logo
818 people viewed this question
Alun Cox
