Question about Ford Vehicle Parts & Accessories
Example of ball joint press usage - Ford Vehicle Parts & Accessories
    Problem Solver:
  • 7 Answers
You can hold in vice and hit with big hammer and use a press to fit new one!i hope this helps
Posted on Dec 23, 2013
I have a 97 Chevrolet Silverado just recently I had noticed my passenger front side tire leaning inward at the top and outward at the bottom. My shocks were already bad so those were changed as were the...
If your ball joints and shocks are good then you need to get the front end aligned. Repeated usage will eventually knock things out of line anyway, but worn shocks will speed the process up. so will worn ball joints.
Aug 31, 2014 | Cars & Trucks
How to change upper ball joint on 93 suburban 2500 4x4
Inspect/Test/Service/Replace Removing Ball Joint Tapers from the Steering Knuckle
The ball joint is connected to the steering knuckle with a tapered connection, called a steering taper, which is also used in other steering connections.
f57-19.gif A ball joint taper. Courtesy of Moog Automotive, Inc. To remove a ball joint requires the use of a ball joint remover.
Another way of "breaking" the taper is to use a large hammer.
  • First, remove the cotter pin from the ball joint nut and loosen the nut several turns.
  • Position the vehicle so that the coil spring is pushing on the ball joint. This could require lifting the vehicle or allowing its weight to rest on the wheels.
  • Use a hammer to pound sharply on the steering knuckle on the outside of the taper. this will deform the taper and spring pressure will separate the ball joint from the steering knuckle.
Removing the Ball Joint from the Control Arm
A ball joint can be retained by one of several methods.
f57-20.gif Three common ball joint retaining methods. Courtesy of Moog Automotive, Inc. Some ball joints are held in with rivets from the factory. The rivets are drilled and punched to remove them. Bolts and nuts are used to hold the replacement joint in place.
f57-21.gif Original equipment rivets are replaced with nuts and bolts. Courtesy of Moog Automotive, Inc. The most common method is press fit. Some manufacturers require you to replace the entire control arm assembly if a ball joint is to be replaced. In these cases, the ball joint and control arm are made as a single assembly and individual parts are not available.
If the control arm has been removed from the vehicle, a pressed-fit ball joint can be removed using a standard hydraulic press. when the control arm is still on the car, a special press set allows the removal and replacement of these ball joints. some pressed-fit ball joints have a spot weld that holds them in place. this must be carefully removed. when a replacement ball joint is installed, a snap ring often takes the place of the weld.
NOTE Be sure the grease release hole in the new ball joint's rubber boot is aimed away from the brakes.
May 09, 2012 | 1993 Chevrolet C/K 2500
2004 kia optima upper ball joint
You have two options. 1. You can replace the upper control arms which come with the ball joints. Replacing is simple. Remove the nut that holds the ball joint to the knuckle. Seperate the ball joint from the knuckle. Remove the two nuts that hold the control arm to the body. 2. Buy or rent a ball joint press. Remove the control arm as described above. Press out the old ball joint. Press in the new ball joint. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 15, 2012 | 2004 Kia Optima
How to replace ball joints
the lower ball joint is pressed into the lower control arm. You will need a ball joint press to remove and install the ball joint. The other option is to replace the lower control arm.
Some parts store will have presses for loan. You will have to check around and see if any in your area have these. If you can't find one you could always pull the control arm and bring it to a shop or machine shop and have them swap the ball joint.
Its a pretty simple procedure.
1. remove the wheel
2. remove the pinch bolt that secures the knuckle to the ball joint.
3. separate the lower control arm from the knuckle.
4. remove snap ring from the ball joint (if it has one)
5. use a ball joint press to press out the old ball joint.
6. press in the new ball joint.
if you don't have a press than you can remove the lower control arm by following steps 1-3 above. then remove the bolt from the front bushing. Remove the stamped steel skid pan from the sub frame. Remove the rear lower control arm bushing mounting bolts.
If you have any questions I'll be happy to answer them.
Oct 13, 2011 | 1998 Dodge Caravan
I need to know how to replace lower ball joint in my custyomer's gmc vandura 1996 model 6.5 d 3500 series.
Hi, the ball joint is connected to the steering knuckle with a tapered connection, called a steering taper, which is also used in other steering connections.
Use a hammer to pound sharply on the steering knuckle on the outside of the taper. This will deform the taper and spring pressure will separate the ball joint from the steering knuckle.
If the control arm has been removed from the vehicle, a pressed-fit ball joint can be removed using a standard hydraulic press. When the control arm is still on the car, a special press set allows the removal and replacement of these ball joints. Some pressed-fit ball joints have a spot weld that holds them in place. This must be carefully removed. When a replacement ball joint is installed, a snap ring often takes the place of the weld.
NOTE
Jul 24, 2011 | GMC Vandura Cars & Trucks
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
Mar 07, 2011 | 2000 Dodge Caravan
How to remove upper and lower ball joins on a 4x4 bronco full size 1986
For Lower & Upper Ball Joint Step by Step :
For That you use a C-clamp style ball joint press to remove the ball joint from the suspension arm-note the location of the receiver cup ! For installation of the ball-joint, use the same tool when pressing the ball joint into the suspension arm-again, note the location of the receiver cup.
Step by Step :
  1. Raise and support the vehicle safely, with jackstands.
  2. Remove the spindle and the ball joint assembly from the vehicle.
  3. Remove the snapring from the ball joint. Using a ball joint removal tool, remove the ball joint from the spindle. Do not heat the ball joint or the axle to aid in removal.
  4. Installation is the reverse of the removal procedure. Torque the ball joint stud nut to 85-110 ft. lbs. for 1983-89 Ranger and Bronco II.
    Please Rate, Thank you !
Aug 13, 2010 | 1994 Ford Bronco
How to replace upper/lower ball joints on a 94 chevy suburban
YOU NEED SOME TOOLS LIKE 1/8 1/2 DRILL BITS.YOU NEED A PUNCH.YOU NEED A BALL JOINT SEPERATOR.YOU NEED BALL JOINT PRESS TOOL TO PRESS OUT BALL JOINT AND PRESS IN NEW BALL JOINT.YOU WILL NEED A HAYNES REPAIR MANUAL TO SHOW YOU PHOTOS AND GIVE YOU YOUR TORQUE SPECS.
Jul 21, 2010 | 1994 Chevrolet Suburban
How do i replace ball joints on 1997 dodge ram 1500
jack up truck support truck remove brake caliper and support the caliper dont let it hang by the hose remove cotter pin from bottom of ball joint remove castle nut from ball joint use ball joint press to push ball joint up and out then use press to push in new ball joint make sure you grease them when you are finished both uper and lower press up and out.
Feb 02, 2010 | 2008 Dodge Ram 1500 2WD
Front end bushing and ball joint do you need to change upper and lower bushings at same time and how hard is to them
It's not required to change the upper and the lower at the same time. However it will save you time if you do them both as if one is going out the other will soon.
The actual job is not that difficult but you may need a pickle fork or a ball joint removal tool to disconnect the ball joints from the steering knuckle. You will also need a ball joint press to remove/install the ball joints. You may also need a strut spring compressor. You can rent these at an auto parts store.
Basically you have to do the following -loosen lug nuts -jack the vehicle up and place on jack stands -remove wheel -remove upper ball joint cotter pin and nut -remove lower ball joint cotter pin and nut -with pickle fork/ball joint removal tool remove both upper and lower ball joints from steering knuckle -disconnect tie rod end from knuckle (optional depending on clearance) -disconnect strut (be sure to install strut spring compressors) -with ball joint press you will need to press both ball joints out (you also use the press to install ball joints)
Installation is reverse of removal.
For exact instructions you can buy the manual for about $20 or go to autozone.com, register, and view the manual on their site for free.
Jan 26, 2010 | 1999 Chevrolet S-10 Pickup
Vehicle Parts & Accessories Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
