Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
I have a frigidaire refrigerator , model ffhs 2313 lso , and it only dispenses crushed ice , I moved the auger by mistake
ebenezer
  • 25 Answers
SOURCE: frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Posted on Aug 10, 2007
SOURCE: Ice Maker offers Cubes or Crushed
sell it
Posted on Aug 12, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
woodchuck789
  • 4059 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
dmftrucker
  • 1922 Answers
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Posted on Aug 23, 2009
Ice maker frigidaire only making crushed
What is the model number of your refrigerator the ice container that has the auger in there has a lever that goes through the bottom of the ice container and then into an opening in the back where it slides into Square opening that moves the lever up and down when you switch from crushed to cubed it changes the position of that lever. Open the door and press the light switch to turn off the light and have someone pressed the dispense ice button with the ice bucket out can you see that part move up and down. Switch it from crushed to Cubed while watching and pressing the dispense ice button. Does it moved? Is there ice build up over that area that may prevent that actuator for moving the lever?
Appliance 911 Sea Breeze
Jun 20, 2016 | Frigidaire Refrigerators
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
PLHS239ZCB2 Frididaire dispenses crushed ice and will not dispense ice cubes
Good Morning Mike,
I understand your Frigidaire refrigerator, model# PLHS239ZCB2, will only dispense crushed ice and not cubed ice. I suggest making sure your ice bucket is in correctly, making sure that the back of the auger is lined up correctly with the drive mechanism. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FRS23H7CS Side by Side...
The ice dispenser on my Frigidaire refrigerator model number GLRS237ZAQ2 will only dispense crushed ice, even with the switch is for cubed ice. Any idea what is wrong?
its right in the manual,rotate the auger 90 degrees till it slides back in the hosing at the back of the freezer and your problem should be solved
Apr 17, 2010 | Frigidaire GLRS237ZA Side by Side...
When dispensing ice, it only gives crushed ice and not cubed even when you are on the cubed ice setting.
most likely the solinoid to change from crush to cubed is bad or frozen. if you pull the ice bucket the metal arm on the back of bucket goes into plastic piece back by auger motor. that is where solinoid is. put finger in plastic piece see if you can move it up and down..
Jan 03, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker only dispenses crushed ice
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker will not dispense ice
your gpoing to have to thaw out the pan that has all the ice in it the the auger will work
May 23, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice dispenser crushed only no cubes
try dumping ice into a bowl running water into the front of tray put ice back in if doesnt work u will need an auger motor
Mar 15, 2009 | Refrigerators
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
