Question about Samsung Office Equipment & Supplies
Samsung ML1640 print fading
When I put in a new toner shortly afterwards the print fades in the middle of the page
SOURCE: faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Posted on Dec 09, 2007
SOURCE: faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Posted on May 02, 2009
  • 30 Answers
SOURCE: black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
Posted on May 28, 2009
SOURCE: Samsung CLX-2160, keep getting faded
Many people will tell you it is an engineering problem that Samsung won't own up to (it isn't and that's why they won't own up to it). Others will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
Posted on Jun 30, 2009
  • 186 Answers
SOURCE: samsung ml1640 print quality is faded down one
try cleaning the internal top part of the printer... if the toner or dust is covering the laser unit.. you will have print out distortion.. like blur print out..
how many copies have you printed with the printer? toner that comes with the new printer is normally less than those replacement toner which you buy later..
Posted on May 23, 2010
Samsung ml1640 print quality is faded down one side unit is only 4 months old and toner is half full
May 22, 2010 | Samsung ML-1640 Monochrome Laser Printer
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
THE QUALITY OF PRINT FROM MY SAMSUNG CLP300 HAS BECOME POOR, WITH SOME BLACK INK FADED
If the print is faded down the length of the page, then the problem lies within the imaging unit. This is a very commn problem with this printer. The developer blades get blocked by a coating of toner, which after many prints, cause a noticable fade in the image. This can be fixed by replacing the imaging unit or the blades can be cleaned. I have detail instruction in my tips section. It can be done quite easily if you are handy, and you could save yourself some money by not buying a new imaging unit.
Apr 22, 2010 | Samsung CLP 300 Laser Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
AFTER RIFILL PRINTER PRINT DIMM
I am using canon toner in samsung printer 1640 it was going perfect now my print is getting Fade
Jun 05, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Won't print an entire page
replace a toner. if one section of the toner is distributing the toner. redistributing the toner is not coming to correct the problem.
best thing is to replace it.
Apr 17, 2009 | Samsung ML-2510 Laser Printer
Faded print on one side of page
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Not printing/ faded printing on middle of page
The HP site suggests replacing the toner cartridge.
This is an excellent, by the way, which has very good troubleshooting ditections
www.hp.com
Oct 11, 2007 | HP LaserJet 1020 Printer
20 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
