Question about Singer Inspiration 4210 Mechanical Sewing Machine
I start sewing and the bobbin starts to come out and then the thread gets all bunedled up under the fabric when sewing. Have sewed most my life and this machine sucks. I keep going back to a 1940 mach
Have changed out bobbin, new bobbin holder, new plate, made sure threaded correctly...still nothing. even adjust the tension.
SOURCE: tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Posted on May 09, 2007
  • 323 Answers
SOURCE: Thread looping on bottom of fabric, and bunching up around bobbin
Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
If it passes this test you need to remove the bobbin case and check for burrs or rough spots. If you find any ,use an emery stick to remove them and then buff the area with fine steel wool.Put the bobbin case back in ,check your bobbin(change it ) and try again by turning the handwheel slowly and watching to see where thr thread is snagging
sewman7
Posted on Jun 18, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 255 Answers
SOURCE: Singer 4623 bobbin thread won't catch
Hi! Did you by chance, change your needle? If so, make sure you have the flat side of the needle shaft facing the correct direction. If the needle isn't in all the way or the flat side of the shaft facing the right way, the bobbin thread won't pick up.
Let me know if this helps, ok?
Happy Sewing!
Posted on Feb 10, 2010
Baby lock quest plus and the bobbin thread is all loopy. I have done everything. I believe it is in tension discs. When I move it to 8 or 9 it sews ok. When I sew faster it seems to start looping.
Is it really the bobbin thread that is loopy--not the top thread looping under the fabric? If this is the case, it is called bird nesting. (problems appearing under the fabric are usually a top thread issue, problems on top of the fabric usually indicate a bobbin issue)
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to loosen the top tension to get it where it should be. The two threads should meet in the middle of the fabric.
If the bobbin thread is still too loose, then an adjustment may be needed to its tension.
Understanding Thread Tension Threads
Feb 10, 2018 | Baby Lock Sewing Machines
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
I HAVE MODEL 12312 AND CANT GET THE BOBBIN TO WORK, THE BOBBIN KEEPS GATHEREING UNDERNEATH MY WORK. ANY SUGGESTTIONS
Please check your fabric results. Is it the bobbin thread that is accumulating under the fabric, or is it really the top thread that is globbing and knotting under the fabric. Usually, thread mishaps under the fabric are the result of an issue with the top thread.
ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disks so the thread will seat properly. Use a brand new needle. Start out with the upper thread tension set midway between high & low numbers, although this can be tweaked.
If it is in fact the upper thread, then here are some suggestions:
Sewing Machine Thread Bunching Up Here Why
Troubleshooting Thread Nesting Sew Toot
Nov 29, 2016 | Sewing Machines
Thread keeps coming out of needle when sewing
When you start sewing, make sure the thread is long enough so the machine does not pull the loose end down into the bobbin casing. It is best to drawn both threads (bobbin and top thread) up through the pressure plate before you place the fabric under the pressure foot.
Mar 23, 2016 | Sewing Machines
How can I factory reset my PFAFF 7550 sewing machine ?
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Feb 28, 2013 | PfaFF Creative 7570
My thread gets all bunches up under the fabric..not from the bobbin thread, from the top thread..do you have any idea what i am doing wrong?
make sure you have the same type of thread in both the top thread and bobbin.
Also make sure your thread tails are clear, by grasping the upper and bobbin threads, making sure they are under the foot when you start. Hold them as you sew the first few stitches so they don't get caught up in the machine.
Sep 25, 2010 | Euro-Pro Deluxe 6130 Mechanical Sewing...
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bernette sewing machine making a mess of thread on back of fabric
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
Dec 14, 2008 | Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
