Question about HP DesignJet 500 InkJet Printer
Hp designjet 500 carriage assembly it's vibrating
The carriage aseembly is vibrating
  • HP Master
  • 1,121 Answers
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Posted on Nov 28, 2012
713printech
  • 32 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
  • 123 Answers
SOURCE: carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Posted on Apr 15, 2010
  • 38 Answers
SOURCE: need instructions to replace carriage belt for hp
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Posted on Jul 12, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Posted on Jul 06, 2011
  • 53 Answers
SOURCE: Diagnostic for HP Designjet 500
I do not understand your question. What do you actually want?
Posted on Aug 30, 2011
Hpdesignjet 500 error code 02:10
Carriage failure.
Replace the Carriage Assembly
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Trailing cable burns
The smoking and melting cable are the result of a short cicuit.
The problem is going to be determining which end the short is occuring on. It most likely is the carriage end of the cable that is the culprit. Most likely you will need to replace the carriage assembly and of course the trailing cable as the new one may have also been damaged.
You may need to use your fingers to check if the top of the carriage assembly (where the cable connects) is also getting hot (warmer than normal).
C7769 60376 DesignJet 500 800 Print head carriage assembly C7769 69376... Trailing Cable for HP DesignJet Plotters Wide Format Printers
Jan 29, 2014 | HP DesignJet 500 InkJet Printer
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
HP Designjet 500 24-in Roll Printer error message 2110
Service Station failure. The possible cause could be:
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
The Aerosol Fan has reached its maximum current limit.
The Service Station motor has shutdown because of blockage.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
1055CM WITH BAD BLACK PRINT HEAD DISPLAY
more than likely the slot in your carriage assembly is faulty. try cleaning the contacts on the carriage assembly if that doesn't help, than more than likely you need to replace the carriage assembly and also the trailing cables. if you are going to keep this printer for awhile than you should also replace the carriage belt. if you can find a certified hp repair person, the cost should be around $500-600.
Mar 14, 2009 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 500 InkJet Printer Logo
295 people viewed this question
Seeker5211
Seeker5211
