Question about Samsung HL-R5678W 56" Television
Loud whinning noise then no picture or sound
After a while of watching the tv it makes a loud whinning noise, as if something is spinning and the ball bearing are shot. It use to go away after a few seconds. Just recently it started to make this sound but the sound got a lot louder. I shut off the set then I turned the set on again but now the picture and sound will not come on. I looked at the rear and the bulb does not light up either.
  • 108 Answers
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Posted on Jan 10, 2009
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
TV picture does not turn on
No,this tv have a colors wheel,it dead.The tv turn black&white,make loud grinding sound,make loud noises like a motor.All indication the colors wheel is spinning off of it axis motor and not functioning anymore.Hire a tv tech.to replaced the colors wheel,very difficult to replaced,many machanicals parts to take out,before even can see the colors wheel to replaced.
Jul 07, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sounds like gear or something is stuck in washer
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. To watch a free video on how to check and replace this part go to www.appliancehelponline.com/servicemanual.html this will walk you thru this. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations.
Mar 30, 2010 | Estate TAWX700JQ Top Load Washer
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have a mitsubishi wd-52525- when i turn on the tv, it sounds as if something is stuck in the fan, no picture, but I do have sound.
the aliens laid eggs in your tv while you were sleeping. you have to destroy the television before they hatch. if you watch survivor they will hatch and you are doomed.
Jun 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung DLP TV (720p) Gray picture, loud spinning noise
It sounds like you have a defective COLOR WHEEL, common problem with DLP's. You need to contact a service comp. for replacement and availability.
Feb 13, 2009 | Samsung Televison & Video
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
High Pitch Noise
there has been a few cases of a coil in the cuircit whinning. and there is a simple fix...applying some silicone onto the coil to dampen it. the coil is ll037 on deflectin board. location m2 a black compnent with coil of copper wire wrap around it. thats my initale thought. it may be more. since you still have a picture.. any questions email me at willie@fordtv.com
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
Samsung HL-R5678W 56" Television Logo
238 people viewed this question
Henry  Thomas
Henry Thomas
