Question about Garden
2006 model 926001 snowthrower. the starter does not engage and the shaft when removed is not stable. Is this still under warranty?
2 Suggested Answers
  • 173 Answers
SOURCE: we have a craftsman snowthrower
Sounds like it has a broken spring on the starter.
Posted on Dec 09, 2010
How to change the starter on Suzuki 2006 atv, model LT-A400/F
Starter is located on top of engine cases under carb. Remove parts as necessary to access the 2 mounting bolts on end of starter that screw downward into case. Remove the starter cable, these 2 bolts and twist the starter while pulling on it to work it free from its mounting hole. Blowing all the mud,dirt and debris from the area beforehand will help and not allow the dirt to enter the motor. A slight amount of prying at the engine engagement end of starter may be necessary. Be careful not the damage starter or case.
Oct 18, 2014 | Suzuki Motorcycles
Starter needs fix
You did not mention the model or make..but most have a simple starting system..the starter ususally is located on the side of the engine facing up for the vertical shaft or front or back for horizontal shafts..two mounting bolts and one or two wires from switch and battery...easy to remove and replace...if you are saying spinning not engaging it is the replaceable spring loaded flywheel engage gearing on the top of the starter...the third would be bad but replaceabke selonoid that transfers the battery voyage to the starter ..just follow the starter sure back it originates at the selonoid...good luck.
Mar 27, 2014 | Briggs & Stratton Garden
Snowthrower starter will not engage flywheel
It shouldn't engage the flywheel except during the moments when you're trying to start the engine. Any other time, it should NOT be engaged so it isn't spinning the whole time the engine is running.
Feb 28, 2014 | Poulan 27 2-Stage Snowthrower,...
2006 jeep wrangler automatic transmission drifts in park
I can't imagine how the drifting in park and the starter won't crank the engine could be related.
It is possible something happened to the flywheel and it is not now connected to the crankshaft, or the bendix gear on the starter is not engaging the flywheel.
But the transmission has a pawl or gear that locks the output shaft of the transmission when the shifter is in park. That gear could be damaged and would allow the truck to roll in park.
And the parking gear would not have anything to do with the starter issue.
I think I would check to see if the flywheel is connected to the crankshaft first.
Is the truck still under warranty ??
Jul 19, 2012 | 2006 Jeep Wrangler
1999 Yamaha XL1200 Waverunner starter always turns
i recomend replacing the solinoide !!!
Mar 11, 2012 | Yamaha Boating
Craftsman Snowthrower, 26"model #247.88970, Starter
You can get parts at searspartsdirect.com Here is the direct link to the parts list for your motor.
http://www.searspartsdirect.com/partsdirect/index.action?SID=CJxPDx Type your model number (247.88970) into the search box.
Go to the engine list and click to order the part.
The part is $147.77 plus shipping to your home.
p.s. Use coupon code 90055 for a 10% discount on the part!
Let me know if you have any other questions.
Jan 10, 2011 | Garden
Can a hidden security system lock out power to essential electronics(fuel pump) to prevent a car from starting???the car's starter does engage,but is getting no fuel...ty
yes it can and if the battery goes dead or is unhooked it will disable the engine from starting and your model has the security system, call your dealer it's under warranty or should be and then will tell you how to reset it. Hope this helps.
Jan 19, 2010 | 2006 Dodge Grand Caravan
Starter drive gear wont engage on a HD fxrs
Sounds to me like the "overrunning clutch" is bad. You'll have to remove the starter and disassemble it. The starter drive is part #31663-90 according to the latest V-Twin book I have. It may have a different number on your 2000 model.
Sep 02, 2009 | 2000 Harley Davidson FLSTC Heritage...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
