Question about Seagate Computers & Internet
My seagate external 1tb will not load said that parameter is incorrect ...what can i do it is about 1/2 full..
  • penny_waly
    penny_waly Nov 30, 2012
    sorry but it didn't help as the drive was broken sent it to the tekguys and downloaded the contents on to a new one ...but a big thank you for all you help anyway!
  • Brian Sullivan
    Brian Sullivan Nov 30, 2012
    thanks for replying sorry to hear its broken nothing seems to last very long these days maybe there designed that way to keep the computer industry moving anyway hope it all worked out for you
  • Seagate Master
  • 27,725 Answers
You must be logged on as an administrator to perform these steps.
If you don't like the letter Windows has assigned to a new drive or you want to organize your drive letters in a certain way, you can change the drive letter.
You can assign the letters C through Z to each drive on your computer.
A and B are usually reserved for floppy disk drives, but if your computer does not have floppy disk drives, you can assign A and B to volumes.
You can see which drive letters are used on your computer by opening Computer.
Open Computer Management by clicking the Start button, clicking Control Panel, clicking System and Maintenance, clicking Administrative Tools, and then double-clicking Computer
Management. If you are prompted for an administrator password or confirmation, type the password or provide confirmation
In the Navigation pane, click Disk Management
Right-click the partition or drive that you want to change, and then click Change Drive Letter and Paths.
Do one of the following
To assign a drive letter if one has not already been assigned, click Add, click the letter that you want to use, and then click OK
To remove a drive letter, click Remove, and then click Yes to confirm that you want to remove it.
You might need to do some diagnostics to find out what is wrong.
If you have nothing to lose, format the machine.
or
You have to erase the entries from the Registry. Run RegEdit.
Source(s):
click start type regedit press enter
or
Use the registry editor and find the key:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevic...
F: as in whatever drive you want to change, and then just change F: to G:
or
If the installation is being run from a network location or if the installation is being run from a directory structure that is several levels deep
(resulting in having too many characters in the path name), this error may occur.
Follow these steps to fix this error:
Copy all the installation files (setup.exe and all other files in the same directory) from the network location or source media (such as the CD) by pressing Ctrl + A or Edit > Select All.
Create a folder on your local hard drive (e.g., Desktop) by right-clicking and selecting New > Folder.
Paste (Ctrl + V) the installation files into the folder.
Double-click setup.exe to run the installation locally.
If the scenarios above are not related to or did not resolve this issue, the error might be caused by something specific to your computer.
The following general troubleshooting tips might help resolve the issue:
Clean the Temp Directory
Install ikernel
Hope this helps.
Posted on Nov 27, 2012
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
SOURCE: Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Posted on Mar 17, 2009
bob_computer
  • 3153 Answers
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
paper bag
  • 72 Answers
SOURCE: dropped my1TB EXTERNAL Seagate drive, now not WORKING
Probably nothing. Hard drives are delicate machines seeing as th have microscopic lasers that are held by a tiny little arm between the discs. If it fell hard, so will all your DATA
Posted on Dec 26, 2009
  • 28 Answers
SOURCE: My Seagate Freeagent Goflex 1Tb
Hello Gravi,
Please try one of the following options.
Try different USB ports.
If that didnt work, then try updating/reinstalling your USBdrivers.
Try after these options a reboot first.
Also take a look at this page where some driver problem for your specific harddrive are explained!
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
I hope this helps you out!
With kind regards,
MisterN
Posted on Aug 12, 2011
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Unexpected turn off
Can you navigate to the external drive via Windows Explorer?
Did you try restarting your computer? Unplug the external completely, then reconnect it?
Oct 21, 2013 | Seagate FreeAgent Pro 1TB External USB...
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Hdd detected however error message incorrect parameters. files not seen
right click on 'drive'
go to properties
click on security
click on your user name in the upper window
and in the lower window select all check box allow
click on apply button then ok
it will work definitely
plus
from explorer, right click the hard drive and properties, and in security tab, click full access for system & users
However if proper drivers are not available then download it from
http://www.seagate.com/ww/v/index.jsp?locale=en-US&vgnextoid=1b0cfbbad0f89210VgnVCM1000001a48090aRCRD
Nov 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I/o error in external hard
make sure all the connections USB, sata and electrical are secure and working properly
Jul 20, 2010 | Seagate FreeAgent Pro 1TB External USB...
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
204 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
