Question about Texas Instruments TI-30XA Calculator
What buttons do I push to calculate continuously compounded interest on a TI-30XA? My professor said to push the e^x button, but it only results in an error.
  • anna_panda
    anna_panda Nov 26, 2012
    I figured it out. I was inputting the information in the wrong order. For the problem "How much will be in the account after 3 years if you start with $20,000 at a rate of 5.5% compounded continuously?" I had put in $20,000 and hit the e^x button, when in fact, I should have put in the 5.5% times 3 years and THEN hit the button, then multiplied by $20,000.
How to type "Ans" on ti-30xa
this can only be done in Multi line calculators.
Feb 17, 2015 | Texas Instruments TI-30XA Calculator
TI-30Xa I need to compound continuously and cannot figure out the buttons to use
Write a formula for your problem than type it in using the appropriate keys.
Sep 17, 2013 | Texas Instruments TI-30XA Calculator
How to push equation into calculator 2x/3+4=2x
Unfortunately, the TI-30Xa calculator does not handle algebraic expressions.
If you are interested in knowing more about the capabilities of the calculator, follow the link to download the guide book.
Mar 01, 2012 | Texas Instruments TI-30XA Calculator
How do I solve a continuously compounding equation on my TI-30XA calculator? An example: 10000(1+.06/12)^10*12
That's 10,000 for 10 years at 6% interest compounded month.
Press
1 0 0 0 0 * ( 1 + . 0 6 / 1 2 ) y^x ( 1 0 * 1 2 ) =
Apr 07, 2011 | Texas Instruments Office Equipment &...
Where is the inverse button on a TI-30XA calculator?
It is the second function of the Pi button.
First you have to push the yellow 2nd button and after the Pi button.
I hope it helps.
Mar 15, 2011 | Texas Instruments TI-30XA Calculator
Where is the e button on a ti-30xa calculator? To find compound interest continuously?
e^x is the 2nd function of the LN key, second from the right on the top row of the keyboard.
Nov 19, 2010 | Texas Instruments TI-30XA Calculator
How to make this operation in my texas instruments TI-30XA 3.55*10(to the 24)
Because this calculator does not allow you to enter formulas, you have to alter the formula a bit.
Instead of entering 3.55*10^24, enter (10^24)*3.55
Note: 10^24 is 10 to the 24.
Here is the procedure:
1) find 10^24. Do this by typing 10, pressing the yx button (which is right above the divide button), and then typing 24. Press the '=' button.
2) multiple the result by 3.55. Press the '=' button.
You now have the answer.
Nov 23, 2009 | Texas Instruments TI-30XA Calculator
How do I calculate compound interest? I want to calculat 3500 (1 +.064) to the exponent 3.5 to get 4348.74. How do I perform this on my TI-30XA? Thanks.
You enter that as follows
3500[x] (1.064)[Y to the x]3.5 [=] . Note that [x] is the multiplication sign.
Hope it helps.
Oct 12, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
825 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
