Question about Acer Aspire 5610-4648 Notebook
Weird French character key
Hi there
if you want a question mark, you do shift + / key
but on my keyboard it shows this key é
which i assume is french, i also wanna type the
double quotation, i get `
left angle bracket i get '
right angle bracker i get .
in other words i am not gettin gthey key i want
i tried fn +f11, didn work
please help
  • canada_eric Jan 11, 2009
    hi i am sorry that i forgot to mention that the problem occurs on ubuntu os
    i did have the sam problem on vista, but i solved the way you suggested, but on ubuntu i am not sure, there is no such thing i can set the lanaguge (or maybe there is i don't know)
    any other thought?
  • Acer Master
  • 5,568 Answers
This is a problem I haven’t stumbled on before and it bugged me so I have a suggestion.
-         Open the Control Panel (generally on the Start menu)
-         Open the Regional and Language folder
-         Click on Languages tab
-         Click on Details
See if the keyboard layout is set to ‘US.’
Now, what I don’t seem to find is how to choose something different without actually changing ‘Language’ itself.
Win ‘Help’ gave this result when searching on “changing keyboard language:”
“You can switch to a different keyboard layout or enter text in other languages without changing keyboards. However, the key labels may no longer match the characters you are entering. Use Regional and Language Options in Control Panel for changing languages and keyboard layouts.”
If this does or doesn't work, please post back as it might help others either do what you want to do or avoid paying any attention to me <grin>
Posted on Jan 11, 2009
  • Steve Allison
    Steve Allison Jan 11, 2009
    Forgot to suggest this in the original; see if Acer will send you the key caps so the characters on the keys now correspond to what they now do.
    I've had luck with this kind of request on a couple of occasions with other companies.
    Problem Solver:
  • 17 Answers
Sounds like a Frenck keyboard, evel things to type on.
try goin into settings and changeing the keyboard language to english
if that dosn't work get tipex find out what each key dose and change it XD
or a better sugestion, I assume that your keyboard has a C type jack and is
going into a purpel port on the back of your computer? what you could try doing
is getting a normal 2.0USB keyboard.
That should solve your probelem as the drivers should be installed into the
keyboard.
Id recomend a "Genius" -cheapest option
or a "Logitec" -a bit more expensive but still good value and way better
Posted on Jul 20, 2009
How can i turn off the green characters on my asus keyboard?
ust press the CTRL+SHIFT keys and you will switch from French to English
Aug 23, 2014 | ASUS Computers & Internet
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
HOW TO GET MY LAPTOP TO STOP USING THE PINK ALTCAR
I found this on another website and it worked for me. Good luck.
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
Sep 25, 2010 | Sony VAIO VGP-WKB1 Keyboard
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
Where is the delete button on a french keyboard!
In wordprocessing or email the backspace key deletes the previous charachter and isnot the same as the Delete key which deletes the next charachter.
On my girlfriend's french pc the delete key is marked "Suppr". It works to delete the next character and also for the "executive override" function which will reboot an old pc or get you to Task Manager in windows.
Mar 27, 2010 | Acer Notebook
When I use the shift key and the question mark , I get the French e symbol instead of the question mark. How do I fix this
Hi there
thi should be quite a simple fix for you
click start then control panel , regional settings , advances you should now be able to see what keyboard layout you are using click add then add the correct one for your language and remove the incorrect one
restart pc and test
Regards AL "alstech"
May 29, 2009 | Acer Computers & Internet
Logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Aug 20, 2008 | Logitech Computers & Internet
Keyboard
that means that the keyboard has been set to a different language. On my screen at the bottom right hand is a little keyboard icon and when i click on it it lets me scroll through US English, Canadian French and Canadian Multilingual Standard. If the keyboard is set to the Canadian French option (or whatever other option that is available on your keyboard in red characters) the number two button changes function.
May 22, 2008 | Acer NSK8458AN Keyboard
Acer Aspire 5610-4648 Notebook Logo
610 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
