Question about New Bright Remote Control Toyota FJ Cruiser
Grandson pushed car around living room, now it won't work -- what to do?
Your car needs new motors
Posted on Mar 28, 2013
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Just fitted a gasslin thermio touch room thermostat and my boiler won't turn on
YOU SHOULD HAVE A LIVE IN & A LIVE OUT THE NUETRAL WIRE IS NOT USED, SO TAPE IT OFF & HOOK THE YELLOW WIRE WITH STRIPE IN IT'S PLACE. HOPE THIS HELPS, GOOD LUCK.
Dec 27, 2012 | Heating & Cooling
My scanner works in one room and not another. However sometimes it does work. There is nothing new around it that would cause an interference in reception. Any ideas what the problem could be?
physical location and the fact both in one location have problems mean something is blocking or affecting signal---old joke: if you turn your head a certain way and it hurts--don't turn that way!
May 15, 2012 | Radio Communications
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
How to connect bose 901 equalizer to yamaha rx-a1000
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input.
http://products.bose.com/pdf/customer_service/owners/og_901.pdf
Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Sep 05, 2011 | Yamaha RXA1000 Receiver
My grandson changed his password & has forgotten it. It won't work. How can he restore his password? Or is this due to the network being down?
It probably has nothing to do with the network being down, and to restore the password your going to need to contact sony.
May 18, 2011 | Sony PlayStation Portable (PSP) Console
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
Hi want to connect bose 901s with active equaliser to my pioneer sc-lx81
http://www.avland.co.uk/pioneer/sclx81/rearlrg.jpg
Oct 09, 2010 | Bose 901 VI Main / Stereo Speaker
Elmo will not turn on, batteries are new
THE SENSOR IN HIM HAS MOVED.FEEL AROUND FOR IT THEN PUSH IT BACK INTO PLACE
Jul 15, 2009 | Gund Sesame Street: Elmo 25" Plush Doll by
New Bright Remote Control Toyota FJ Cruiser Logo
118 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
