Question about Sun Computers & Internet
I can not get java to work with windows 8 - Sun Computers & Internet
  • 1,263 Answers
Can you give me the error message ? is the os installed 32bit or 64bit ?
Regards
Posted on Dec 16, 2012
Why won't my volume wont work on pavilion dv7
Step 1: Using the Troubleshooting tool in Windows 8 The Troubleshooting tool in Windows 8 can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run the Troubleshooting tool first before you manually correct problems.
To open the Troubleshooting tool:
  1. At the Start screen, type find and fix audio to open the Search charm. Figure 1: Find and fix audio search
    c04030165.jpgShow all ' Hide all [img id="doc_plus_doc_sc_6.1" src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/hpweb_1-2_plus.gif" alt="show" >
    Update the audio driver from the HP Web site
    [/a] hpweb_1-2_plus.gif
    Update the audio driver using Device Manager in Windows 8
    Step 4: Checking Device Manager to troubleshoot audio problems (Windows 8)
    If you cannot hear sound, check Device Manager to determine the state of the sound hardware.
    1. At the Start screen, type device manager to open the Search charm. Select Device Manager in the Search results. Figure 13: Device Manager
      [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c04030167.jpg" alt="Device Manager on the Search screen" title="Device Manager on the Search screen">
    2. Double-click Sound, video and game controllers .
    3. Do the following, depending on what displays:
Jul 14, 2014 | HP Pavilion dv9000z Notebook
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    Download java installer for samsung notebook 3 windows 8
    Here is the installer for windows 8 for java runtime. I am assuming this is what you need as this is a common plug in. http://javadl.sun.com/webapps/download/AutoDL?BundleId=81819
    After you install Java you can go to this site in your browser in order to see that java has been installed correctly. https://java.com/verify/
    You must restart your browser prior to going to this verification page
    Dec 12, 2013 | Computers & Internet
    Cant get java downloaded on windows 8
    Under "add remove programs" delete all versions of Java then go to http://www.java.com/en/ and download the most current version.
    Oct 25, 2013 | Computers & Internet
    Google chrome is loaded in windows 8 but is running in desktop ,which means i cant use java or other etc
    as of what I understood from what you have written(I didn't understand most) you want to run two instances of Chrome in the "Modern style Windows 8" and the Desktop, sadly it's impossible as to many crashes and bugs with it = http://www.youtube.com/watch?feature=player_detailpage&v=Rfh5Ioih0Is
    Just an example.
    So, can you please answer these questions (don't type fast, write it clear and short), so that I can finally understand your problem:
    1. Is Java installed on your PC?
    2. You are using Windows 8, right?
    3. Your primary browser is Chrome, yes?
    4. IE10 "Modern" can't run Java or Flash?
    5. Does the Desktop IE run Java and/or Flash?
    If you have more details = just add them at the bottom.
    Mar 25, 2013 | Computers & Internet
    I have downloaded pogo but still can't play
    this can be problem due to backkground software missing from the system, use this link to download java on the system and this should help you in playing pogo and it should work, you should also upgrade your internet version to internet explorer 8 if it is an older version,
    use this link for
    java :- http://tinyurl.com/8a3ov
    for upgrading to internet explorer 8 :- http://tinyurl.com/d2a6yy
    download the following applications i am sure you will be benifitted with it..
    Mar 28, 2010 | Microsoft Windows XP Home Edition
    Internet Explorer 8 crashing when I login to facebook. Help pls!
    Try checking what addons are running in IE, it could be a Software conflict , aslo update flash/java/shockwave
    also, try loading the page through a proxy
    https://cowclock.com
    you can use the firstbar but it disables client side scripting
    Glype works pretty well and CGI is java re-rewrighting
    good luck!
    Sep 04, 2009 | Microsoft Internet Explorer 8
    My search results return a blank white page.
    If you are running with Window XP then please see this and follow the instruction given by me:
    Use IE 6.0 instead of IE 7.0
    or use a new Web Browser such as Firefox or Google chrome, see this Tip posted by Me:
    Google Chrome for All XP or Vista user
    Let me know in either case if you have any issue remaining, dont vote till you get the solution.
    Scott
    Nov 21, 2008 | Microsoft Internet Explorer 7
    Java
    If you don't already know how to program then i wouldn't start with Java but maybe with Visual Basic. Once you have a good grasp of Basic then you can move onto Java.
    If you already know how to program in another language, especially C++ then you will find java to be quite familiar.
    In any case your first step would be to go to yoru local book store and buy a book or two. Read through the book while at your computer and try all the examples.
    For Visual Basic there are books like this: http://www.amazon.com/Microsoft-Visual-Basic-2008-Step/dp/0735625379/ref=pd_bbs_sr_1?ie=UTF8&s=books&qid=1215519837&sr=8-1 or http://www.amazon.com/Beginning-Microsoft-Visual-Basic-Guides/dp/0470191341/ref=pd_bbs_sr_6?ie=UTF8&s=books&qid=1215519932&sr=8-6 or http://www.amazon.com/Teach-Yourself-Visual-Basic-Hours/dp/0672329840/ref=pd_bbs_sr_9?ie=UTF8&s=books&qid=1215519932&sr=8-9
    For Java you may want to check out: http://www.amazon.com/Head-First-Java-Kathy-Sierra/dp/0596009208/ref=pd_bbs_sr_1?ie=UTF8&s=books&qid=1215519994&sr=8-1 or http://www.amazon.com/Beginning-Programming-Java-Dummies-Computer/dp/0764588745/ref=pd_bbs_7?ie=UTF8&s=books&qid=1215519994&sr=8-7 or http://www.amazon.com/Sams-Teach-Yourself-Java-Days/dp/0672329433/ref=pd_bbs_9?ie=UTF8&s=books&qid=1215519994&sr=8-9
    Jul 08, 2008 | Microsoft Windows XP Professional
    Computers & Internet Logo
    145 people viewed this question
    Top Sun Computers & Internet Experts
    Cosma Papouis
    Cosma Papouis
    Robin Hill
    Robin Hill
    Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
