Question about Hitachi Deskstar 3.5 - 500 GB 7200 rpm IDK-PANAM Desktop External - Retail Box H3IK500327... Hard Drive
Lost power adapter for Hitachi Deskstar HDP725050GLA360 Exteranl Harddrive How do you recover the data without electricity?
Plugged another adapter by accident thinking it was the right one and now my harddrive just blinks and no results.
    Sergeant:
  • 198 Answers
If the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Posted on Nov 27, 2012
3 Suggested Answers
SOURCE: Recover Data from Hitachi Deskstar (Model: HDP725050GLA360)
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Posted on Jul 23, 2010
multilinkent
  • 739 Answers
SOURCE: Hitachi Deskstar - Model HDP725050GLA360 Sata 3.0
if the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Posted on Feb 20, 2011
I Am having trouble with my hard drive for some reason it will not appear on my computer anymore anybody have any ideas a message will pop up saying you have a high speed usb 2.0 device plugged in and will...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 15, 2011 | Hitachi HDP725050GLA360 500 GB SATA Hard...
Hitachi Deskstar - modelo HDP725050GLA360 Sata... tengo este modelo de disco lo tengo en ungabinete externo de disco se cayo y ya no lo,lee tampo en una comutadora como puedo salvarlo
Hola que tal, tengo malas noticias, cuando un disco duro se cae lo mas probable es que se dañe, lamentablemente no hay forma de reparar el disco pero sí de extraer la información que está grabada en él, cuesta muchisimo dinero extraer la informacion ya que requiere de equipos y personal calificado para la recuperación, si la información es muy importante y si puedes pagar aproximadamente 600$ por la recuperación el camino a seguir es buscar una empresa de recuperación de datos en tu país.
Lástima darte estas malas noticias...
May 30, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
Hitachi Deskstar - Model HDP725050GLA360 Sata 3.0 500 GB S/N RJ3KSXHE Clicking sound after being dropped. Is there any hope of recovering the data on this drive at a reasonable price?
Feb 20, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
When I plug my my Hitachi SDM/205 250GB Simple Drive into the usb port a pop-up window appears and says that it needs to be reformatted. Have I lost my data?
Yes, but there are many recovery software that you can download from the internet.... so don't worry, try 4shared.com by searching Recover My Files which is very effective. Please note to format your HDD using Quick Format rather than Full Format.. Good luck..
Apr 20, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I want put my Hitachi Deskstar 7K250 80GB Hard Drive from a t2885 emachines on a HP/Compaq K8N8X-LA mother board without losing my data.
You won't loose your data Why wold you think you would? once data is written to a hard drive it remains there until it is removed be a user, it works on the same principlea a floppy, the magnetic coating on the surface of the anodized disks inside of the HD are written to and retain memory of the data, the only things in a computer that won't keep their data are the RAM chips which need electricity running through them to work.
Dec 07, 2009 | Hitachi Deskstar 7K250 80GB...
I'm trying to get information off my harddrive using a usb to ide adapter and I keep getting "you need to format" the drive, if I format it I will lose the data I am trying to recover off from it, what can...
Ignore the format drive pop up and open the "my computer" icon and see if the drive is listed in the devices shown there. If it is click on that drive and the files and folders will appear like any other. If it doesn't appear right off, reboot, but leave the drive attached vis USB and see if the computer will recognise it and list it.
Oct 30, 2009 | Hitachi Deskstar T7K250 HDT722525DLAT80...
Feb 28, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
I have an older deskstar 41gb that I slaved for files and it just died. How can I recover the files from the disk? I think the electronics have failed on the PCB.
Send it to me. http://techrxgb.com TechRx, Inc. of Wisconsin. Data Recovery company. Offering free estimates. We have specific tools that emulate the pcb's of hitachi and makes for simple recovery of your data.
Jan 06, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
HITACHI deskstar hardrive. model HDS722580VLAT20
Send it to TechRx, Inc. we are a data recovery company in Wisconsin. We offer free shipping and estimates. I have specific tools (hardware) that will SA emulate Hitachi drives; and that makes for easy recovery of your data. http://techrxgb.com
Nov 15, 2008 | Hitachi Deskstar T7K250 160 GB Hard Drive
Hitachi Deskstar 3.5 - 500 GB 7200 rpm IDK-PANAM Desktop External - Retail Box H3IK500327... Hard Drive Logo
97 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
