Question about Intel Foxconn 661FX7MF-S Socket775 SIS 661FX Micro ATX Motherboard - Retail
I have a Foxconn sis-661 motherboard and am wondering what is the max size of hdd i can run on it 1Tb-2TB?? thanks guys
  • Intel Master
  • 3,606 Answers
Hello the home page is here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000097
The mainboard is not limiting the size of the harddrive.
But windows does.
You heard correct in relation to the 2TB limit.
The root of this is Windows XP x86 is MBR only meaning that the limitation is to do with MBR
Disks exceeding 2TB must use GPT which extends the limit significantly, however Windows XP does not have this support currently.
A 32 bit version of windows generally will only see the protective MBR on a GPT disk.
Information on Windows Disk support can be found here:
http://msdn.microsoft.com/en-us/windows/hardware/gg463525#removablemedia
Or course, that being said, I have seen external drive manufacturers combining a GPT loader in with their drives which will allow Windows XP x86 I/O on a drive greater than 1TB, this may be the case in your situation. The GPT loader I have come across is called Paragon GPT loader. I would imagine this would cause lag on I/O as it is another stack process.
You will need a new operating system/computer (Yours is from 2005)
to use very large harddrives.
Hope this will help you
Posted on Nov 27, 2012
map9966
  • 2351 Answers
SOURCE: max size sata drive for pcchips a31g
Hi Jason_UK, the motherboard revision does not matter in regards to the SATA size. (The board does support SATA).
2TB is a limit imposed by the MBR partition table. Assuming the disk uses 512 sectors.
If the sector size is increased to 4KB, the limit becomes 16TB. Suggest you setup your serial ATA SATA disk drives by downloading the manufactures bootable floppy disk setup software. Most SATA manufactures also provide bootable CD software if you do not have a floppy drive in your system. You will be able to change the size of the clusters allowing you to have access to the entire drive. The floppy software will also allow you to format the disk & there are other features that can be turned on or off. Neither windows nor the bios can make these changes.
Good luck Jason!
Mike
Posted on Sep 09, 2008
DickCanFixIt
  • 948 Answers
SOURCE: I'd like to know the sequence to connect the
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Posted on Apr 27, 2009
  • 33 Answers
SOURCE: no drivers for Foxconn 661 7MI motherboard
If the foxconn motherboard you have is just like the model below:
661GX7MI-RS
661FX7MI-RS
661FX7MI-S
661GX7MI-S
this are the links for their driver.
for USB 2.0
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000681
for Onboard Video
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000458
for On-Board LAN Drivers
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000457
for
On-Board PIDE/SATA Drivers
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000456
for
On-Board Audio Drivers
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000455
for
AGP Drivers
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000454
Posted on Sep 07, 2009
map9966
  • 2351 Answers
SOURCE: manual for foxconn motherboard 661 mo fx 6ls
The Foxconn link provided below shows all 661M series motherboards;
http://www.foxconnchannel.com/en-us/searcher.aspx?key=661m
Re-check your model number.
Mike
Posted on Sep 25, 2009
clokker
  • 253 Answers
SOURCE: i am looking for a motherboard owner's manual
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=566
Posted on Jan 18, 2010
What size hard drive can i use for a samsung shr-7162 16 channel dvr and what is the best hard drive recommended
Always use a HDD rated for continuous use such as the WD purple range. Do NOT use a standard PC HDD as these are designed to keep switching themselves off and back on when accessed and are not rated for continuous. The manual says max 500Gb but I have used 1tb drives with no problem. As they are SATA I would have thought there should be no issue with up to 2Tb but the may be issues above this according to the filing system used. Best thing would be to get any old larger drive you could borrow to try if you really want to go large. With 5 internal drives I would have thought 1Tb drives would be enough. In personal experience I have had more failures with Seagate/Samsung drives than with anyone else's and the most reliable (no failures to date) have been HGST.
May 13, 2015 | Samsung Home Security
What is the maxium hard drive will my k8v-x support
You have to limiting factors when determining max HDD size. 1) IDE or SATA interfaces. 2. 32 bit or 64bit Operatings System. With a 32 bit OS you are limited to 2TB per drive. Although I think 500GB is the largest IDE drive you can get.
Nov 23, 2011 | ASUS K8V-X Motherboard
Please could you advise me if i can get a compatable dual core proccesor for my Foxconn 661M03-G motherboard Motherboard ID 05/26/2006-SiS-661-6A7I4FK9C-00 please would you recomend a proccesor that will...
Sorry but that motherboard does not support dual core processors. The socket type is 478 which is Pentimum 4 and will support anything up to a 3.2 GHz processor.
Regards.
Jan 05, 2011 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
What size of sata hdd i can connect to mb mercury pi945gcm????
you can connect any size SATA HDD to your system. Depending upon the OS and drivers you may have to create logical drives to handle the capacity. If you decide on a large capacity HDD such as a 1TB drive, backup becomes an issue. You may want to keep your working drives to a manageable size and attach a backup hight capacity drive for backup.
If you have any questions, please let me know.
Please rate this solution. Thanks.
Aug 30, 2010 | Mercury P4VM800M7 Motherboard
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
Apr 27, 2009 | Foxconn Computers & Internet
Max size sata drive for pcchips a31g
Good luck Jason!
Mike
Sep 09, 2008 | PC Chips Computers & Internet
Problem when running games
Sounds very much like the capacitors are gone. Have a close look at all the capacitors. I think you will find some that have bulged at the top, may or may not be leaking brown liquid. If they are, look at it as an opportunity to get a better board!
Aug 01, 2007 | Foxconn 661MX Motherboard (FOX661MXMB)
Audio driver
-chipset: AD 1888
-driver: SOUND MAX
-SIS 760
Jul 25, 2007 | Foxconn 760GXK8MC-S Motherboard
Intel Foxconn 661FX7MF-S Socket775 SIS 661FX Micro ATX Motherboard - Retail Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
