Question about Locks & Locksmithing
Recut keys dont work in weiser smartcode door lock
Bought new weiser smartcode lever door lock. Wanted to have all the doors in the house use these new keys (in case smartlock doesn't work). Have had 8 keys recut and none will work in the smartcode lock. The master keys work well. The master and recut keys look like they match. What should we do?
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
VtToolMan
  • 704 Answers
SOURCE: Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
VtToolMan
  • 704 Answers
SOURCE: Weiser combination lock for front door
You can reset the lockset to change the master code and then enter in other codes for use by contractors, delivery people, etc. which you can then delete as you wish without having to give out the master code.
Rather than give you the simple step-by-step instructions for resetting the lockset, I've provided a link to the user manual so you can have it available for use and reference, as I assumed you didn't have yours any longer.
  • 12650 Answers
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
Posted on Oct 19, 2009
  • 15 Answers
SOURCE: how do i change my code on my weiser front door
page 6ish
Posted on Nov 06, 2009
Why do my weiser smart key locks turn to the 3 o'clock position?
I looked at the Weiser site and although it describes the method of re-keying the locks it doesn't make it clear whether the key can be removed in the 3 o'clock position without the learning tool being inserted.
If the key can be removed in that position it would seem it would only need the key to be reinserted and the lock turned back, though somehow I doubt it as that would rather defeat the object and mean you wouldn't have to keep changing the locks.
Whatever the cause is, it would seem either one of the staff or one of the residents is having a game with you, perhaps they have seen this youtube video...
https://www.youtube.com/watch?v=sR-h64WwfW8
Jun 18, 2017 | Smart Cars & Trucks
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Front door toggle and knob assembly replacement
I installed a weiser smartcode lockset and the motor is turning the wrong way. How do we fix this?
2 important things which may seem dumb but solved my problem:
- Make sure that once everything is in place, you hold the lock button before inserting battery pack (and keep holding the lock button) until you hear 2 beeps. The latch should come and go.
- Last but not least, make sure you put NEW batteries in... I had old batteries and when i tried it seemed like is was working but could not finish the door direction finding sequence stated above. Make sure they are new and it should work!
Feb 14, 2010 | Weiser Lock Locks & Locksmithing
The kids locked the bathroom door and closed it... my
Oct 19, 2009 | Weiser Lock Locks & Locksmithing
We rekeyed our deadbolt and for some reason the key does not work and we can't unlock the door (from outside)..help!
The lock tang (the item between the two lock parts inside the door) has been turn 180 degree out of position. Take the lock off, turn tang 180 degrees, reassamble, and it should work like new.
Sep 01, 2009 | Weiser Lock Locks & Locksmithing
Locks & Locksmithing Logo
65 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
