I have a Intertherm Model mgha-056abfc-02. I am having trouble with the fan switches. I tried to replace with an aftermarket, but it did not work.
I have found one at one of your distributors but it does not match the part number 626337 on the outside exactly (Mine has a "B" on the end) is that OK? also I was going to replace the switch next to it while I was at it. part # 6263360 but I haven't been able to find this one. can you help me with this as well?
carldc3
  • 82 Answers
SOURCE: INSTRUCTION MANUAL /INTERTHERM FURNUES
usually a power surge will fry the transformer unless sometimes if your lucky the manuf. installed a fuse either in line or on the circuit board. 5 amp or 3 amp....any thing bigger wont protect your equipment.
Posted on Jan 10, 2009
  • 659 Answers
SOURCE: heat does not work when thermostat calls for heat...
This is a safty limit switch. Find two wires that are going to the inducer or combustion blower that terminates to a small disk about the size of a penny. In the middle of those two wires should be a small button. Push firmly down thus reseting the switch. This should do it. It could also be the pressure switch but I have never heard it called that before. If the first doesn't fix the issue. Remove the small tube that runs from the inducer to a black or silver disk, blow out and draw in air until you hear clicking noises. Sometimes they can become stuck. If that doesn't work, remove the other end of the tube from the pressure switch and blow through it. Sometimes debris can clog the entrance to the pressure switch as well. Hopefully this will solve your problem. You can have a bad limit or a bad pressure switch. In this case you will probably have to call someone out.
Posted on Apr 08, 2009
bobicehouse
  • 1524 Answers
SOURCE: Intertherm model MGHA-090-AAPQ -- combustion air keeps running
Sounds like a problem with the circuit board.
Posted on Apr 23, 2009
  • 89 Answers
SOURCE: Intertherm MGH-056ABFC-91 won't kick on. Just
There is probably more than one limit switch. I'll have to get a wiring diagram of this unit. See if you can follow the wires from the wires from the limit switch and see if they go to another limit switch. Also you can put a jumper wire on the red wire and white wire on the unit outside and see if ti comes on.
Posted on Nov 03, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: pilot light won't stay lit
possible bad thermocouple.
Posted on Jan 14, 2010
I need wireing diagram for model # mgha-056abfc-02 gas furnace
Contact the manufacturer/distributor to request it.
Jan 16, 2018 | Heating & Cooling
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
Intertherm wiring diagram for model number MGHA-056ABFC-05
you have a 24 volt shorts check your thermostat wires to see if they are frayed or if they are touching anything. Check your outside wires also go to the thermostat.
Jul 12, 2014 | Intertherm Heating & Cooling
INTRTHERM MODEL MGHB -056ABFC-09 FAN KICKING IN OUT EVEV WHEN WARMED UP
The fan speed might be set to fast cooling the fan limit control prematurely. Or the fan limit switch is not calibrated correctly. Or the fan limit switch is bad.
Dec 21, 2013 | Intertherm 56000 Btu Gas Furnace
I have a intertherm gas furnace mgha-056abfc-01 the pilot light will not stay light.
If it's not the limit switch, perhaps the thermocouple or gas valve is defective.
Was there a gas outage?
Oct 24, 2012 | Heating & Cooling
Instalition of intertherm model#MGHA-077ABFC-02
Here you go, get back with me if you need anything.
b220604d-b686-4495-96f4-93ea09674f99.pngd8d58f98-1a98-4a3e-b181-e1355d1fe66e.png6c0ca38c-f240-4b92-9e02-4ef2cef42c38.png
Aug 30, 2012 | Intertherm 56000 Btu Gas Furnace
My intertherm mgha is having pilot issues. The
The problem will be in what senses the pilot is lit. Either a thermocouple or maybe it uses an electrode and flame rectification. If it is an electrode you can try cleaning it. If it is a thermocouple you will have to replace it.
May 02, 2010 | Heating & Cooling
WHERE DO i GET A BURNER PILOT FOR A NORDYNE HEATHER SERIAL # MGH9412-04786 MODEL # MGHA-056ABFC-02
Nordyme makes a lot of different units. Go to Nordyne.com service and parts they can help. Rus
Nov 17, 2009 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
