Question about Toshiba Computers & Internet
PC cannot send data to printer error on toshiba message help!!!
  • Toshiba Master
  • 5,660 Answers
Unplug the printer from power, and from the computer. (FROM the computer, not from the printer)
Open the printer as you would for replacing ink cartridges. Close it.
Plug into computer. Plug into power. (In that order)
Turn printer on.
This procedure resets the printer, and clears Error Codes.
It may be that the USB cable from computer to printer was loose; or it is bad.
You may also have lost Drivers.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Printer is the device in question; Windows XP, Vista, 7; is the O/S.
Try the above first, then we will reinstall the drivers.
Post back in a Comment.
Also; what is the error message. Write it down. (I know. It comes across the display like a ticker-tape )
Regards,
joecoolvette
Posted on Nov 26, 2012
Model AR-6020. What does error message "PC cannot send data to printer. Please check power and data cable" indicate?
Check the network connection and or the USB cable. Go to Sharp web site and download the latest drivers for your machine and computer. they (drivers) are normally free.
http://siica.sharpusa.com/product-downloads
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 14, 2016 | Sharp Office Equipment & Supplies
CONFIG 1*
If the printer is showing "CONFIG 1*" this is not an error, this message is simply advising that Menu CONFIGuration 1 is selected hence the * beside the message.
Assuming the settings in CONFIG Menu 1 are correct if you send data to the printer in the correct format it should print.
May 03, 2013 | Tally T6218 Matrix Printer
Toshiba Satellite l775-14 has an error message and won't turn on
Buy an external caddy/docking station for your hard disk (IDE or SATA), take the drive out and attach it directly to another PC and access it from windows on the other machine to save your data.
Apr 25, 2012 | Toshiba Computers & Internet
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
We've a problem with our TEC printer B-SX55. Sending a job via parallel interface only results in an error message showing up: XS;I,0001,0012C5 Can anyone tell me what to do to get it up and running...
This type of error message usually means a command error has been found in a command received by the printer. 16 bytes of the command error, hence the XS;I,0001,0012C5 message. It starts from the command code, XS.
I am not sure of all the command codes but I would suggest starting by re-installing the printer driver.
Dec 17, 2010 | Toshiba B-SX5T Printer
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Not Printing correctly
This may me due to various factors.
- The parallel port is only unidirectionnal. You should use ATcompatible for this port instead of ECP on the computer.
- The driver sends data in topix compression not understood by your printer.
- there is problem on your parallel port
Mar 12, 2009 | Toshiba TEC B-572 Printer
Error 1201 Lexmark x4250
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used."
To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Thank you
Nov 03, 2008 | Lexmark X4250 All-In-One InkJet Printer
Facing problem with outlook plz help
Either the message you are trying to send is too big, e.g contains a too large attachment, or your mailbox on the server is full...
Mar 31, 2008 | Microsoft Office Outlook 2003 for PC
Open Questions:
How To Fix Laptop That Won't Turn On 'Call +1888784-9316 In case you have encountered certain issues while working on your important project from office or while doing college assignments due the next day and now you are searching for some strong supportive tech support service, then get in touch with the tech support executives of Dataalign. Call Toshiba support for getting rid of all sorts of tech issues whether related to software or hardware. Getting tech issues fixed in a matter of few minutes is the speciality of tech support executives of Toshiba support. These executives of Toshiba are certified professionals and they make proper use of their expertise and years of working experience in the field of customer support for customizing a unique and exclusive tech support service according to the required need of the customer. We can say that Toshiba tech support is the simplest, effective and customer friendly tech service. It has got everything that makes a tech support service high in demand, like being pocket friendly, easy accessibility, available even at the odd hours, courteous and polite support executives. These technicians always try that all the customers they deal with, get satisfactory outcome and also experience friendly customer service. Toshiba laptops are famous around the world for their eye catching features and advanced technical characteristics that make them everyone's first choice. Still Toshiba customers face issues in their devices ranging from minor issues to major ones that can gradually lead to effecting the laptops performance permanently for a long term. Issues that are usually faced by customers are not able to process fast, getting the command keys wrong, screen freezing issue, blue screen of *****, frequent invasion of viruses, Trojans and malwares etc. Toshiba support has been helping customers to get rid of all these issues as soon as possible. Their assistance is available 24/7 through various modes of communication like via mail or through phone. They employ advanced techniques for resolution of issues and they use remote access process for their work which makes is more accurate and faster. Call on toll free helpline number +1 888 784-9316 anytime and get support anywhere. Enjoy the work being done in front of your eyes by asking for tech support service at the time and place of your choice.
Jul 17, 2018 | Toshiba Computers & Internet
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
