Boot CD is not being recognized when trying to install hard drive
I am trying to install a new WD Caviar Black hard drive but the boot CD that came with it is not being recognized by my computer. I have set the BIOS to boot to CD but when the disk is in the drive nothing happens. No errors nothing my screen just says, ''Boot from CD/DVD :'' then has the cursor on the next line. I know that the program is not with my CD drive because when i put the windows vista instillation disk in it will go through the setup untill the actuall install where i get a mesage telling me that i need to format my hard drive. Any ideas that can help me get this fixed are apperciated. Thanks!
  • 4 more comments
  • nick90 Jan 10, 2009
    OK i tried using the DLT files (for both versions 11.2 and 11.0) on a CD. Both of those were read but when they ran they just produced errors that were as follows:
    NWCDEX.EXE Version 2.81 CD-ROM file handler
    Driver not found: 'generic'.
    A:\NWCDEX.EXE requires a driver name to be specified.
    Invalid drive specified
    Command of filename no recognized (4 lines of this)
    any other ideas?
    I replaced the hard drive because the previous ones were making terrible clicking noises and the RAID0 array that they were in was not bootable.
    I tried formatting the disk in Vista and i now shows up as having the a partition but i now am getting a error in vista when i try to move on to the next step. The error says that windows could not determine if this computer contains a valid system volume.
    i removed both drives in the array and deleted the raid stripe.
    so, to clarify further, i now have only 1 hard drive in my machine connected to the SATA port 0 (raid was in 0 and 1)
    i know for a fact that one of the original drives still worked but that drive alone was not going to be enough storage space for my needs, thus i purchased the new drive
    Just for anyone else who encounters the same or similar chain of events i went through, i ended up resolving the problem in my BIOS. i had the boot order set to CD then disabled the other two options. When i adeed back in hard disk drive after CD drive vista continued instilation just fine. The reason this worked was because at that point in the vista installation the computer was trying to run off the HDD rather than the vista disk and with no HDD turned on it no workie.
    Thanks to all who helped on this for me! :)
    Master:
  • 461 Answers
Why not use the Vista disc to format the drive. At the bottom of the Install screen after the License Agreement you should see Drive Options (Advanced) where you can select the partition. You may have to create the partition using the New option, but formatting is automatic with the Vista install. If you are not able to do this something may not be correct with the drive setup - either jumpers or BIOS settings.
Posted on Jan 10, 2009
  • 3 more comments
  • Curtis Richner Jan 10, 2009
    Could you provide more information as to why you replaced the hard drive in the first place? Could be a memory issue.
    Sorry, you refer to RAID array, but then you state you replaced one drive. Have you confirmed you replaced the failed drive or both? Have you recreated the array?
    Although unlikely, it sounds like there may be an issue with the new drive. Have you tried just one of the original drives? It is also unlikely that both failed at the same time.
    Other than trying to use the good old drive, I can't think of an easier way to determine if the problem you are having is the new drive or some other issue with your system.
    Wow! I never would have thought you'd done that. I guess I should have asked. Thanks for sharing the resolution so others may learn.
My boot CD had a tiny scratch on it and the drive would not initialize the Cd. I had to go to another machine and download the info and burn it to another CD in order the use the boot.
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
Installed a new WD Caviar into a Dell Dimension 5150 to replace failed Hard Drive. Wont boot on start-up. A cant find drive message comes up. F1 through it and starts up OK. Seems to be recognising the...
Restart your computer.
Enter BIOS SETUP.
Check the list of disk-drives (and CD/DVD drives).
You have "manually" added a device that no longer is connected.
So, you get the "cannot find drive" is generated.
Disable/Remove the non-existent device,
and then you will not need to press 'F1' to continue.
Nov 07, 2010 | Computers & Internet
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
EXTERNAL HARDRIVE NOT RECOGNIZED IN WINDOWS XP
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
May 30, 2010 | Western Digital Elements powered by WD 320...
I have a Western Digital 80GB drive that can no
Spooler Ap Not working is a typical printer problem. You need to check the printer system for that. DO you get any kind of message in boot screen? If nothing happens you insert a boot disk and try if it is booting. If that doesn works you might have lost some IC in *********** board.
Aug 16, 2009 | Western Digital Caviar SE WD800JD...
Installed more ram and now can't find the hard drive
Pull out the new RAM chips and install the old one or ones and see if it boots ok. I had this same problem. This can also be caused by no using matched sets of RAM chips. In my case I added one and used the factory one as well, caused the same issue as you have.
May 19, 2017 | Western Digital Caviar SE 80 GB Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hard drive install
Could really use a lot more information, but to start you might
check your bios first to see if your computer is recognizing the HD, (XP will try to install just using RAM). Make sure your drive jumpers are set properly. Master, slave or CS?
Dec 16, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Install hard drive
you need to be a bit more specif please, try and provide as much info as possible
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
Computers & Internet Logo
715 people viewed this question
David Payne
David Payne
