Question about HP Computers & Internet
Adding more memory to my compaq presario - HP Computers & Internet
    Problem Solver:
  • 7 Answers
I need more information what kind of memory for starters.
Posted on Nov 26, 2012
3 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: Adding Memory
Hello.
i search your computer and the computer has two memory bank(slot) containing 512mb exh bank. total of 1024. Please see the details of your computer here: http://h10010.www1.hp.com/wwpc/ca/en/ho/WF06b/12132708-12133156-78308260-78308260-78308260-79685091-80248998.html
and here is the steps in adding the memory. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&cc=ca&lang=en&dlc=en&product=3377253#N813
on that information maybe can carry the motherboard upto 2GB memory. You can change maybe each slot ot the memory to 1GB per slot to have you total of 2GB.
may this help. melnavz
Posted on Mar 24, 2008
bunnydawg
  • 5158 Answers
SOURCE: I am thinking of adding
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Posted on Sep 19, 2008
Presario sr1710nx what type memory
Crucial.com has an excellent wizard for locating memory.
Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC...
Lists memory compatible with your machine.
Memory Type: DDR PC3200, DDR (non-ECC)
Maximum Memory: 4GB
Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
Nov 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Added new ram to compaq presario sr1750nx and worked fine at first.. now wont boot
Try taking the newly installed RAM out and re-seating it. If the persists you might have a bad block on the memory chip
Mar 12, 2011 | HP Compaq Presario SR1750NX PC Desktop
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
HP Compaq Presario SR2150NX PC New Memory not recognized
Remove the Old memory and see if the system reconizes it, if yes the old is not compatable together.
If no the new memory is not compatable with your system.
Aug 29, 2009 | HP Compaq Presario SR2150NX PC Desktop
The monitor reads: system boot failure. Insert recovery disk.
McAffee Security or adding memory cards should not effect the ability to do a system recovery, but so be it. Here is a list of presario laptops, do you know which is yours?
s.gif s.gif s.gif » Compaq Presario 12XL325 Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ20-325TU Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ45-325TX Notebook PC
s.gif s.gif s.gif s.gif s.gif s.gif » Compaq Presario CQ40-325AX Notebook PC
» Compaq Presario CQ40-325LA Notebook PC
» Compaq Presario CQ40-325TU Notebook PC
If so, click on it and you will find the recovery disks.
Mar 18, 2009 | Microsoft Compaq Presario C501nr Notebook
Supposed to have 20 GB of memory, only have 1.99GB
Use windows 98 to make a rescue disk (3 1/2 floppy)
use that emergency disk to repartition and format the hard drive. You can probley use fat16.
Mar 11, 2009 | Compaq Presario 5000 PC Desktop
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
Pp1020 ram
Hi Doug-
Your Compaq Presario 1020 comes with 16M RAM and can be upgraded to 48M total
(by adding a 32 MB EDO RAM 5 volt SODIMM in the single available memory upgrade slot)
Nov 05, 2008 | Compaq Presario Notebook
Compaq Presario 5352 memory installation recognizing
be sure that the memory u got is compatible in your presario 5352. I tell you that adding 512mb to current 64 mb maybe a problem. you should remove the 64mb and replace it by 512mb and be sure that the new memory is compatible. want more information about your presario go to www.hp.com then search "compaq presario 5352"
melnavz
Dec 12, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
