Question about Toshiba E-Studio 162 D
PC cannot send data to printer error - Toshiba E-Studio 162 D
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: PC cannot send data to printer error on toshiba message help!!!
Unplug the printer from power, and from the computer. (FROM the computer, not from the printer)
Open the printer as you would for replacing ink cartridges. Close it.
Plug into computer. Plug into power. (In that order)
Turn printer on.
This procedure resets the printer, and clears Error Codes.
It may be that the USB cable from computer to printer was loose; or it is bad.
You may also have lost Drivers.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Printer is the device in question; Windows XP, Vista, 7; is the O/S.
Try the above first, then we will reinstall the drivers.
Post back in a Comment.
Also; what is the error message. Write it down. (I know. It comes across the display like a ticker-tape )
Regards,
joecoolvette
Posted on Nov 26, 2012
Model AR-6020. What does error message "PC cannot send data to printer. Please check power and data cable" indicate?
Check the network connection and or the USB cable. Go to Sharp web site and download the latest drivers for your machine and computer. they (drivers) are normally free.
http://siica.sharpusa.com/product-downloads
Jan 14, 2016 | Sharp Office Equipment & Supplies
What does "100 %" stacked mean?
it means that the printing order for the memory for the printer is full
go to control panel , go to printers and hardware , click on printer right click and it will show a section see what is printing
high light each line and delete that takes away the priority of the stack until there is nothing left to print and the printer should again print at the next selection you make
How the program works is this
there is a small memory in the printer and a large one in the pc
when you have data that is to be printed, the pc sends the data until the printer memory is full at which stage the printer starts to print. new data is sent as memory space becomes available until the document is printed
when different data is requested to be printed or there is a hiccup in the process the pc looses the priority in the print list ( page number or new document)and so backs up that memory and becomes blocked
by going into the pc in the printer hard ware and deleting the printing waiting to be processed your are unblocking the process and allowing the pc to again move data to be printed
Nov 08, 2015 | Brother Office Equipment & Supplies
Kyocera fs 1028 error pcl xl kernel error operator 0x6b position 938
PCL error is telling you that the printer does not understand the data being sent. Could be a corrupt or incorrect driver, or the program you are printing from is sending corrupt data.
Aug 28, 2015 | Kyocera FS-1028MFP
WHAT IS ERROR FRAMING 411?
Errors 001 to 405 and 429 to 435 are data errors. This type of error indicates that incorrect data was sent to the printer, and the printer is ignoring it. Your System Administrator should correct the packet and send it back to the printer. Error 411 is baud rate mismatch. Here's the manual:
http://www.monarch.averydennison.com/support/servdocuments/User_Documentation/9855rfmp/9855rfidoh_aj.pdf
Jun 17, 2014 | Monarch Paxar? 9855 Label Printer
Turn printer on.
Regards,
joecoolvette
Nov 26, 2012 | Toshiba Computers & Internet
HP d135 All-in-One it keeps giving me a scanner error - battery. Where is the battery located?
Scanner, put your scanner settings to "Skip preview and send directly to photo view center". If I set this option then I don't get the error. Its only when I use preview and then accept that I get the error. It may be that the usb port sends the data too fast or the data to tell the scanner to crop is corrupted in the scanner memory and the only way to clear it is to turn on and off. What if you sent the accept function through a network card that plugs into the back of the scanner, does it still get corrupted? Or what happens if you use an older slower usb port to send the data. I did everything, clean the glass, change battery. But this is the only thing that worked. Respond and tell me what happens with your printer. Thanks.
Dec 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
Got error of "PC cannot send datga to printer. Please check power
my printer, I got error of "PC cannot send data to printer. Please check power and printer cable connections and retry printing". Please help me.
Apr 02, 2009 | Sharp AL-1642CS Copier
Toshiba E-Studio 162 D Logo
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
