Laptop turns on but no picture,it only turns on when battery is removed
The laptop power light will come on only when the battery is taken out and the adapter is plugged in,when the battery is in,there is no power.
  • 7,627 Answers
Is the battery good? A replacement? Have you tried a diferent battery with same specs? Different cord/charger? Any damage to laptop?
Posted on Nov 26, 2012
ctf1800
  • 4402 Answers
SOURCE: won't turn on
*Unplug the AC cord
*Remove the battery
*Locate the memory cover on the underside of the notebook
*Unscrew the one or two screws securing the memory cover, and lift up to remove the cover
*Gently slide (away from one another) the metal retaining clips that hold down the module.
*The module should pop up
*Remove the module
*Reinstall the module (removing and reinstalling the module is apparently enough to rectify the contacts)
*Replace the module cover and the battery
*Attach the power cord
*Try to power up
Posted on Jan 21, 2008
  • 52 Answers
SOURCE: HP Pavilion 8000 power light and battery light blinking
hi,
Hp recalls some king of batterys, maybe yours it is on this recall, contact hp web or phone to take advantege of this recall, otherwise appears that your battery do not work you may replace it.
Thanks
vcrtech
Posted on Apr 27, 2009
Tech 75
  • 85 Answers
SOURCE: Sony Vaio PCG 7v2l won't turn on
this may or may not be the solution but its some sort of indication of what is going on. Ok when you plug the ac adapter do u get a flashing light to indicate your batter is being charged? If you do then there is power going through the laptop to the battery, which is great. Now if you don't have the indicator flashing then it could be that the where the AC adapter plugs to the laptop could be now faulty. The other one could be that the AC adapter plug i.e. head that goes into the laptop some how internally has a severed connection.
comment on what you find and ill see what else i can advice :)
Plz rate me
Posted on Jun 02, 2009
mrstan
  • 242 Answers
SOURCE: Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Posted on Aug 29, 2009
Testimonial: "Thanks for your answer. I guess I will check what the repair costs may be, and if too much, just get a new machine."
tbirdfan1
  • 3051 Answers
SOURCE: Gateway mx6030 laptop won't turn on
Hello there:
hopefully you got the right adapter for the machine and if so and still no lights or nothing you can try to hold in the resetr button on the back of the machine and turn on the power at the same time and see what happens if still nothing i would look at getting the machine serviced by a authorized dealer
you may have a bad board or the internal cmos battery is dead or there is a loose connection somewhere ok?
best regards michael
Posted on Sep 10, 2009
My screen does not turn on
  • Remove all power (adapter power Cord and Battery (for laptops))
  • Hold down the ON button for 30secs (dispersing internal voltage)
  • Plug the power cord in only (ie leave battery out, for the moment)
  • Turn on
Check your power adapter. Plug it in to a known good power receptacle. See if the power adapter has any lights that light up to make sure it is getting power.
Take the battery out of the laptop and just only plug in the power adapter.
Do any lights on the laptop light up when you power it on? Does it beep?Does it make a sound? Is where you plug your power adapter to your laptop loose or broken?
if no sound or light the its either power adapter , dc jack or cable, or system board .
Please note, it is also a good measure to re seat the memory.
You may need to locate your disassembly guide
Aug 14, 2014 | Compaq Presario R3000 Notebook
Not powering up at all. Taken battery out and should power up through charger however nothing. Model sony vaio pcg-3d1m Please advise if anyone else had similar problem. Thanks
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 06, 2012 | Computers & Internet
Ive got the Samsung R519, just bought a new battery for it but doesnt seem to have made a great deal of difference, its only 2yrs old! Wont turn on when on adapter & battery removed & no charging...
From the description you have motherboard issues, sub out the ram memory one at a time to see if you can get it started, no change! the dc jack in the laptop is a common source of trouble from no power to intermittent operation, at this point the laptop will need to be taken apart for further examination.
Jul 03, 2012 | Samsung R519-53S Notebook
I have an acer 4520 lap top. I can't get it to power up at all. When I push and hold the power button the green light comes on around the power button and the three lights in the upper right side flash...
first remove your battery and try to switch on your laptop with good power adapter if still have the same issue ?? just remove your memory and reinstall after clean your memory if still have the same issue ?? remove your memory and cmos battery and switch on it with a good power adapter.after 2 minute you can re install back your memory and cmos battery and try to switch on it.
Sep 14, 2011 | Acer Aspire 4520-5582 Notebook
XPS M1210 Laptop not powering up
No Power Issues on Laptops
There are 3 things to consider in order for you to determine a No Power Issue
1. Battery
2. Mother Board
3. AC Adapter
1. Remove the battery from the laptop
2. Disconnect all non essential cables (external hard drive, usb memory key, printer...etc.)just connect the AC Adapter
3. Take out the Battery....Usually there is a battery indicator that you can push at the back of the battery
4. By Now the battery power indicator should be full since it was never taken out
5. If still theres no light on the battery.... replace battery
6. Turn the laptop on without the battery
7. If the computer still did not turned on check the AC Adapter if there is light coming out
8. If there's no light that comes out from the AC Adapter. Reseat the cable from the AC Adapter to the Cord
9. Check if there is no light that comes out from the AC Adapter. AC adapter needs to be replaced
10. Otherwise the Mother Board needs replacing
May 17, 2011 | Computers & Internet
I GOT A BLANK PAGE NO PICTURE
try to turn off the laptop then remove cables and battery. Press and hold power button for 8 secs. Reinsert the cables and battery then turn it on. If it is no picture check if there are lights on keyboard, then call your PC provider for repair..
Apr 19, 2011 | Computers & Internet
I have a Compaq CQ50. It will not turn on. when I hit the power button, the small electric sign flashes, but nothing else happens. I have taken the battery out, but there is no change. this is...
Please check your power adapter and see if your adapter has a LED light when you power it on. If it doesn't then it's most likely that your power adapter is faulty and needs replacing. If the light is on, then send your laptop in for warranty/repair. Either the internal power supply unit or motherboard is damaged.
Mar 08, 2011 | Compaq (CQ50Z) PC Notebook
I have a dell 5100 laptop. This morning i removed a program through add/remove programs. The computer need to be restarted. During the restart I left and came back the power light was blinking so I pressed...
Our expert technicians provide you dell tech support for desktop, computer, laptop, printer, drivers, etc. Call at our number 1 (800) 204-4427 and get 24X7 quality services.
May 19, 2017 | Dell Inspiron 5100 Notebook
The laptop wont turn on. i have unpluged it, taken out the battery then replace it after 60 sec. tried to turn it on and it didnt work. i plugged it back in waited about 5 min and it still wont turn on....
This sounds like a motherboard problem, unplug computer and remove main battery and leave it out. Now plug in power adapter, press power, if no! remove the hard drive, power up to see if you get a screen prompt, If no! remove one stick of ram, if no! remove the second stick and make sure you put back the first one, if yes! the stick in your hand is bad, if no! there is a motherboard issue. If all this fails put everything back except the battery and power supply, next hold down the power button for 40 seconds, after that time install battery and power adapter and press power "this is a last ditch effort"
Feb 11, 2011 | HP Pavilion dv6000z Notebook
Was scrolling through pictures recently taken. camera suddenly froze - can't go forward , can't go back, can't turn off the power, can't take a picture -- the power light just stays on and none of the...
Taking out the battery would do no harm to your pictures. Also in some models of cameras you can force it to shut down by holding the power button for 10 seconds. Might be worth a try . If not you can always remove the battery.
Oct 27, 2010 | Kodak EasyShare M1033 Digital Camera
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
