Question about Mitsubishi VS-60719 60" Rear Projection Television
Mitsubishi Vs-6071 Picture
Ok I have this T.V. and everything was working fine the picture works great but some some reason none of the inputs work includeing the coaxial inputs. I have reset the tv and and realigned the picture still nothing. Not sure what it is. Please help.
  • Eric Schultze Jun 07, 2007
    I get no signal from the cable box
Replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Posted on Jun 05, 2007
SOURCE:
Vs 60111 Fuzzy picture
Its a very old set and if happens on all inputs and cables have been ruled out something serious--the rear inputs bypass the tuner in the set and based on its age I would not suggest spending major money (if you can find someone willing to work on a set of this age) on this set.
Many parts for this are no longer available.
Aug 20, 2012 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi WS-65611 losing HD signal
Not to worry.Its really a Great tv...But...the only thing you should do to fix this just get it hd ready and your and dont get it integrated with an hd receiver and everything will be fine!
Oct 11, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
VS60601 Picture yesterday, none today
That model will usually leak coolant directly onto the vertical output area and that will put the tubes into protective blanking and you will have sound but no picture.
Aug 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Oct 03, 2007 | Mitsubishi VS-60719 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
