Question about Whirlpool LGR6611L Gas Dryer
LGR6611LQ0 Thanks for your reply. Quick question: Can't I use an adjustable wrench and put it on the backside of the fan (which is square)... then turn the shaft... letting the wrench push against the flooring to the left (Facing from front) while turn shaft counter clockwise? I think what I really wanted to know is how it's connected... and you answered that... screwed on. I wasn't sure if it was pressed on and the end of the shaft was square.
  • 3 more comments
  • corvettece Jan 10, 2009
    Thanks. I tried turning it and found it quite hard so I decided to stop and post the question. Wanted to make sure I didn't break the plastic and have to buy a new blower fan too. I'll let you know what happens when I try tomorrow afternoon. Thanks again.
    Ok... changed motor and nothing. Still wont start. The last tech that came in said it was the motor. Everything is hooked up correctly... maybe ON button? Man this stinks....
  • corvettece Jan 11, 2009
    Dryer would not start. The last cycle was completed... checked the dial... went to do next load, would not start. When pushing start button, I can hear it engage... when turned to off or unplugged, i can hear it disengage. Had a tech over yesterday, said bad motor and couldn't change it until Monday. Said no go, I'll change it myslef. That's where you came in. He checked each connection, got juice... that's where he decided it was the motor. No bad sounds came from it, went through a dryer a few years ago... could tell when going bad. So that's that. Last resort, buy a new one :(
    motor is connected correctly. what wires would i jump? i have two blues, one pink/black and a fourth wire that looks like it heads to a little black box behind the panel.
    Motor is connected correctly. what wires would I jump? I have two blues, one pink/black and a fourth wire that looks like it heads to a little black box behind the panel.
  • 640 Answers
You can but now you have to turn the motor shaft at the belt end..i believe you can put your adjustable behind the plastic square blower wheel shaft..on the motor shaft and try turning with your hand its hard to turn because the drum when turning turns the oppsite way,,im,,here onthejob..use gloves
Posted on Jan 10, 2009
  • 1 more comment
  • onthethejob1
    onthethejob1 Jan 10, 2009
    shot a little dw 40 mon today,,ok at the blower wheel end and motor shaft,,,now i have been servicing appliances for a lot of years and sometimes you may have to crack it of ,,,it happens,,keep me posted onthejob
  • onthethejob1
    wow your making me look bad,,,i thought you had a bad motor,,,i came in on the middle of picture,,im going to jump ahead ,,what was you orginal problem ,,,dryer would not start ,,,check your door switch,,please reply from the beginnig othejob
  • onthethejob1
    onthethejob1 Jan 11, 2009
    the next thing is to jump out the push to start switch.i dont give up..your sure you put the motor back correctly..
I have a 2008 Kia Sorento LX 3.3. where is the adjuster bolt for the idler pulley? Trying to change serpentine belt and idler pulley.
The idler pulley deflects out of the way using a special wrench, the pulley is held against the belt only by a preset spring tension mechanism. You put the wrench on the bolt or in the square drive hole and deflect the pulley away from the belt, it must be manually held there to put the new belt on and then released to tension the new belt.
Feb 10, 2012 | 2008 Kia Sorento 3.3
I am not sure how to remove the head and body screw from inside a binks model 7 spray gun....it is tight and dont want to break anything
remove bottom adjustment screw this is the fluid adj rod will be a long one, then you should have a special wrench that came with gun , there is a square surface behind the tapered head that seals to the fan cap put wrench on the square part and remove, being careful noy th burr up tapered surface on front of valve, then you can thourly clean out gun, make sure not to loose any seals during process, do not sand or use abrasive material on these parts, use lacquer thinner and brush,you do not want to bend or scrape these in any way shape or form, caues then your gun will not spray right when reassembled. good luck
Aug 06, 2011 | Garden
How do i keep the pulley from turning when changing the fan clutch 2000 Dodge Durango
put a adjustabli wrench on the backside of the pulley and then hold it and take the fan off
Oct 14, 2010 | 2000 Dodge Durango
Motor heats up and stops running how do remove
The blower fan on this model has reverse threads where it screws onto the motor shaft. At the small space between the motor and the rear wall of dryer you will see that the blower wheel has a square neck that will allow you to hold it stationary with a large crescent wrench. while holding the blower grip the pulley on the front of the motor with another wrench (or channel locks) and turn the motor shaft clockwise to break the blower loose. Sometimes a quick motion is better to free it as it may be on the motor threads pretty tight.
Good luck on this!
Jul 11, 2010 | Whirlpool LER7646E Dryer
How do i get the fan shaft off so i can get the water pump out?
There is a tool for it but you can use a big wrench put it on the fan shaft nut with the belt still on so it holds the pullley, give the wrench a quick hit to the left with a hammer to break loose then spin off.
Sep 26, 2009 | 2003 Chevrolet S-10
How to use the stenley roofing sqaure?
take your board make a mark on the side of board put your speed square on that mark(the squared side)flat up agianst the board rotate the square until the 15 deg comes to the other side of board then make your line.
Apr 06, 2009 | Stanley 46 - 050 10 - 3/4" x 6" Quick...
Problems with Ford fan clutch wrench.
what i used to do to hold it and you need two people to do it.... is to have one person apply pressure to the fan belt so the pulleys would not turn.... then hold the fan blade with one hand and loosen the bolts
Mar 19, 2009 | 1991 Ford Explorer
How to remove fan from dryer motor LGR6611LQ0
ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
Jan 09, 2009 | Whirlpool LGR6611L Gas Dryer
Replace fan belt
Here is a diagram http://www.2carpros.com/car_repair_information/tec_info/2002/ford/mustang/2002_ford_mustang_drive_belt_routing_diagram.htm
its pretty simple use a wrench/hex which ever applies to the nut that on the tensioner some vehicle have a regular bolt type and some have a hex. Just follow illustration and push on tensioner using proper tool and release tension and belt and the belt will come and replace using the routing diagram I provided. Good Luck and Thanks for using FIX YA contact if you need more help.
Dec 31, 2008 | 2002 Ford Mustang
Water Pump
it unscrews there is special thin wrenches to hold pulley and remove fan it unscrews normal(counterclockwise) u can sometimes use channel lock plers you will see the pulley has two small holes there is a tool that fits in thes to hold while removing fan blade. might can get thru autozone loan a tool
Sep 12, 2008 | 2004 Chevrolet Suburban
Whirlpool LGR6611L Gas Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
