Compatible Graphics cards asus a8ne-fm - Computers & Internet
SOURCE: Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Posted on Jan 28, 2008
Buschchris1
  • 474 Answers
SOURCE: Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Your board is PCI EXpress so as long as you get a PCI express Video card you should be fine. Just dont get a video card with a Faster Bus speed than your Mobo or else its wasted potential, but other than that, ** problem, have fun playing video games :)
Posted on Mar 10, 2008
Nic61
  • 1073 Answers
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
  • 28 Answers
SOURCE: graphics card compatibility
That mobo is here"
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138090
It says it has a PCIe x16 slot, so really good graphics cards running on PCIe x16 will work on it.
This is a list of the PCI express x16 cards you can buy:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609641&name=PCI%20Express%20x16
Generally the more they cost the better the performance but that is another story =)
If you wanna to hit me up with your full PC specs of CPU, RAM, Windows version, etc, i could recommend cards for certain games.
It also has PCI so older and less powerful PCI cards can likely be used.
Posted on Mar 19, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
Tip
Fixing the noisy fan a8ne-fm
ok     i did this two days ago and it worked for me. 1  Turned off psu 2  Opened the case 3  remove graphics card from pci-e slot 4  unplug the small circular fan in the bottom corner of motherboard.  5  unscrew the cover on the top of the fan 6  clean in the fan/heatsink with scewdriver whatever 7  get your screwdriver under the plastic fan bit and raise it slightly from its heatsink     only a little tiny bit though.      8 leave the top cover OFF 9   plug fan back in and install graphics card 10 power on at psu
It worked for me no noise and have been playing cod4 quite a bit
on May 20, 2008 | ASUS A8N-E Motherboard
Doesn't recognize graphics card
make sure card is fully seated in slot. try removing and reinstalling card
Jan 30, 2010 | ASUS A8N-SLI Premium Motherboard
TV-out problem on my geforce fx6600 graphics card
boot into safe mode (F8) and uninstall the video card.
Dec 09, 2009 | Nvidia GeForce FX6600 512MB PCI Express...
Computer will not start,audible alarm every 5 seconds
Check your power supply. A beep every 5 seconds or so generally indicates a problem with power supply voltages.
Apr 09, 2009 | ASUS Computers & Internet
Motherboard graphics compatability
Here is the manual for your MotherBoard.
http://dlsvr.asus.com/pub/ASUS/mb/socket939/A8N-E/e1911_a8n-e.pdf
U can upgrade to anyone of the cards u want as long as they are Designed for PCI Express® x16
Nov 11, 2008 | ASUS A8N-E Motherboard
Version of PCI Express
my motherboard has a PCI-E 1.0 it's an Asus Commando graphics is 9600GT which is PCI-E 2.0 and it runs fine till now no prob about that mate PCI-E 1.0 and 2.0 is backwards compatible so it should work fine make sure your graphics card is working @ x16 coz when I first plug my graphics it runs only @ x2 then I reset the bios and re-seat the graphics now fully functional x16 of PCI-E lanes.
May 15, 2008 | ASUS A8N-VM CSM (00610839133826)...
PCIe 2.0 compatibility
Yes it will work, though a nvidea card may yeild better performance overall in your system.
Feb 12, 2008 | ASUS A8N-SLI Motherboard
Jan 28, 2008 | ASUS A8N-VM Motherboard
Once installed Asus A8N SLi will not boot up in Vista 64 bit
Link: http://support.asus.com/download/download.aspx?SLanguage=en-us
Make sure that you have the lastest Firmware installed in your BIOS.
Also run Windows Vista Upgrade Wizard before installing Vista to check for compatability.
Note: Vote for me......
Jan 27, 2008 | ASUS A8N-SLI Motherboard
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
