Question about Exercise & Fitness
Sporstart 1060 Hr Treadmill, display leds blinking, keys not working
    Top Expert:
  • 12,223 Answers
1) Replace the batteries, with the same kind, and type, and the same polarity.
2) Clean the contacts batteries, with c. cleaner
3) Adjust the REED swithc, test it, clean it, and tight the connector.
4) Tight the Ribbon cable for keypads.
God bless you
sporstart 1060 Hr Treadmill, display leds blinking - 11_27_2012_11_58_26_pm.gif11_27_2012_11_59_32_pm.gif
Posted on Nov 27, 2012
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Sportsart 1060 hr treadmill
please LUBE the deck belt as shown in the video and fix it.
God bless you
May 31, 2013 | Exercise & Fitness
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    Sports art 1060 not working
    please adjust the REED switch, clean it, test it, and tight the wires connector, see the diagram attached.
    2) tight the ribbon cables from keypads switchs, and clean it.
    3) tight wires connector from display board vs lower board see the block too.
    4) replace the batteries by new ones, and clean contacts batteries with contacts cleaners
    God bless you.
    Jul 29, 2012 | Sportsart Exercise & Fitness
    No stop key indication and treadmill wont power on
    Check the 2 fuses under the motor shroud. One should be a 10 Amp fuse, the other should be a 15 Amp fuse.
    Is the red LED lit? If not, check outlet, check power cord for treadmill. With cord unplugged, check the connections on the motor control board for the AC input, which are marked AC1 and AC2.Plug cord back into the wall outlet, and check voltage at those terminals- it should be 90 volts or higher.
    If those check out- replace Motor Control Board,
    Dec 31, 2011 | Startrac Fitness Products Star Trac 4500...
    Immobilized
    Immobilized feature is activated.
    Press and hold the SPEED Down
    Arrow Key and press the Pause Key to
    toggle ON/OFF.
    Aug 19, 2010 | Life Fitness 9500HR Next Generation...
    Screen/Monitor not working after moving treadmill
    +11v LED - Indicates there is +11 volts supplied to the display board. If this LED is not lit verify the following: 1. The display cable is damaged or pinched, disconnect the display cable and verify if the LED lights up. If LED lights up replace the cable. After the above has been verified and the +11 LED is still “OFF”, the MCB should be replaced.
    Jun 14, 2010 | Startrac Fitness Products Star Trac 4500...
    Wont turn on, LED just blinking
    Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
    Gggenau offered a rep at 400-500 eur for this ! Shame on them !
    S:DOlberg
    Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
    Exercise & Fitness Logo
    74 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
