Question about Sharp LC52SB55U LCD TV
Can't hear the output speakers
I've hooked up the output audio to a Bose Wave radio. I'm not getting any audio output.
Is there a setting I'm missing?
  • kitpumpum Jan 10, 2009
    Although I had tried all of the suggestions (and still didn't have sound), your recommendations put me on a path to just start all over again and be sure all the connections and settings were correct.....voila.....enough sound to enjoy the new Blu-Ray player (the audio is really low on some of these movies).
    A great experience. Thanks!!!!!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Make sure you have the cable hooked to output. Go into your televisions menu and set the speakers to external. That will disable the interior speakers on the television. there are actually two options. You can set it to fixed output, internal speakers off. This is best for just using the Bose speakers all the time. Or you can set it to variable output; internal speakers on. That way you can watch TV late at night and use the internal speakers and not "bother" those sleeping. Or crank up the Bose when everyone is watching! Make sure you have the Bose set to the proper input as well. Good luck!
Posted on Jan 10, 2009
LEFT SPEAKER ON BOSE RADIO NOT WORKING
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 03, 2014 | Bose White Wave Radio Ii Am/Fm Radio Model...
Bose wave type clock radio has no volume
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 08, 2014 | Bose Wave Radio
Installed a Sony Xplode into a 99 Blazer and everything on the radio works but will not play through the speakers
The Bose system is complex - it has an amplifier separate from the Bose compatible radio. This amplifier takes low level audio signals from the radio, not full driver outputs from a replacement radio, and by trying to use the replacement radio you may have blown the amplifier. If that is the case, you may not be able to go back to the original radio.
The only option you may have with the replacement will be to find the Bose amplifier and bypass the connections to feed the replacement radio outputs directly to the speakers. This may not be as simple as it sounds, as distribution to the various speakers comes from the amplifier, not the radio, and the wiring from the amplifier to the radio may not have all the wires you need. Before going on, you had better get a wiring diagram for the Bose system (service manual or Alldatadiy.com).
Jun 11, 2017 | 1999 Chevrolet Blazer
I would like to hook up an HD tuner to my Bose Wave Radio through the RCA input jacks . . . . I've done this with an iPod and it worked . . . . will the tuner play through the Wave Radio?
Of course it will if it has audio outputs. For all the Bose knows it's just a standard external audio device. What keeps you from just trying it?
Jun 26, 2011 | Bose Wave Radio
Would like to connect Bose Acoustic Wave II sustem
If your TV have audio output ( RCA or any kind ) then you can hook that up ( you can buy the cable from radio shack ) then to BOSE audio input w/c is the AUX input.
Apr 26, 2010 | Bose Wave Radio
I have a Bose Wave, Multi CD changer and wish to output my TV audio to it. Bose reps say all I have to do is connect Red & white audio cables to the AUX input on the CD changer and to the TV's Red...
The only other solution for this would be to connect the red and white RCAs directly to the source that you're trying to hear. (i.e. cable box, dvd player etc.) I have seen a convertor that will go from digital coax to RCA, but I'm not sure how reliable it would be. Plus a good one would be very expensive for what you're trying to do. You could also get an RCA switcher. Connect all or your components (cable box, dvd etc) to the switcher, and an RCA output to the Wave system.
Jun 18, 2009 | Bose Wave Radio
Trying to connect external speakers
check with radio shack to see if they have something that will plug into the rear jack of the Bose...and has leads that you can wire to your speakers
May 27, 2009 | Bose Wave Music System CD Shelf System
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Bose Wave Radio/CD - Sound from only one speaker
Sounds like the audio transformer, but it's difficult to tell because Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 06, 2007 | Bose 683-0332FB CD Shelf System
Sharp LC52SB55U LCD TV Logo
614 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
