Question about Frigidaire FEF366DC Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
The right front cooktop element will not shut off...it seems to be stuck on "HI". From everything I've seen on websites, it appears that the burner switch needs to be replaced. Professional Series Model # PLEF398CCC.
  • donald_newbe Jan 10, 2009
    My controls are on the back panel above the cooking surface.
  • Bill Newberry
    Bill Newberry May 11, 2010
    That is correct. Definitely one of the switches are stuck "on". Are your controls on the front of this oven or on the back panel above the cooking surface?
    Thanks
    Guru:
  • 93 Answers
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Posted on Jan 10, 2009
I have a mod#fef389wtfce ser#vf81815803 and to change the burners but theknobs are in front on top by the oven door inside there 4 screws to take out is that it
Posted on Jul 24, 2011
How do i fix a heating element on my electric cooktop
Most top elements are just a plug in.. find where the element joins the body of the stove and firmly pull on the element straight back from that point. MAKE SURE THE POWER TO THE STOVE IS TURNED OFF AT THE BREAKER
Mar 02, 2015 | Kitchen Ranges
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Frigidaire FEF366DC Electric Kitchen Range Logo
2,534 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
