Question about KitchenAid Architect® II KBMS1454S Stainless Steel 1000 Watts Microwave Oven
HOW TO REPLACE WAVE GUIDE ON KITCHENAID KBMS1454R
WE HAD A SMALL FIRE INSIDE THE MICROWAVE. THE HUMIDITY SENSOR GOT DAMAGED AND THERE IS JUST A HOLE IN THE WAVE GUIDE WHERE IT USED TO BE. I HAVE REMOVED TOP AND THERE IS NO DAMAGE TO ELECTRONICS.ITHE MICROWAVE SEEMS TO BE OPERATING FINE, BUT I DON'T KNOW IF IT IS SAFE TO OPERATE WITH THAT HOLE IN WAVE GUIDE. IF IT IS NOT I WILL NEED INSTRUCTIONS ON HOW TO REMOVE AND REPLACE BOTH THE HUMIDITY SENSOR AND WAVE PLATE. THANKS FOR ANY HELP YOU CAN GIVE ME ON THIS.
MicrowaveSvc
  • 9098 Answers
SOURCE: Kitchenaid KBMC147HSS0 Bulb replacement
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
SOURCE: Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Posted on May 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: need to remove kitchenaid microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 21, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Dec 25, 2008
A hole has appeared in the panel of the roof of my Miele microwave oven model H4060BM type MW6004 is this dangerous and can it be repaired?
If the hole is in the wave guide cover, that can be replaced. After removing it, you would need to inspect the inside of the wave guide, and clean it if there is food or grease in it. If any arcing has occurred, damaging the paint, it needs to be repainted.
If the hole is in the metal part of the cavity itself, that can be dangerous, and it's generally impractical to repair.
May 05, 2016 | Miele Microwave Ovens
My GE microwave is starting to arc, You can see the arcs on the plate (I believe it is the wave guide cover) on the right side interior. Burn marks are evident on teh plate. Is it the waveguide cover or...
Some units use a plastic or fiberglass cover over the wave guide where the microwaves are dumped into the oven cavity. If this cover gets coated with food/grease, or soaks up grease, it can arc, or catch fire. If unit is still operating properly otherwise, I would suggest replacing the cover. You need to inspect the wave guide, also, to make sure it is still intact, and there are no cracks in it that would allow microwave radiation to escape.
Apr 17, 2014 | Maytag MMC5000 Microwave Oven
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
Magnetron has 2 small holes in antenna due to previous wave guide being dirty.Is the microwave still safe to use,no sparks or arcing.
Some magnetrons have holes in the antenna by design. If these are clean holes on opposite sides near the RF gasket then they belong there. If the holes are obviously burn damage but don't cause any improper operation, the oven is safe to use.
Apr 10, 2010 | Sharp R-820B Convection/Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Clicking When Unit Starts
Q - When there is small amounts of food in the oven, arcing occurs right behind the plate where the wave guide comes into the oven. Sometimes it works well and sometimes you can't even put in a bag of popcorn. Any ideas? Could food have 'dripped' in here and be causing a microwave short?
A - Yes! Food splatter or drips can continue to cook and will carbon over creating sparks/arcs from the wave guide cover. Usually can clean up the food on and under the wave guide cover, if the oven liner has been damaged we usually lightly sand and touch up those marks with touch paint. Do not let it go for too long as damage to the magnetron end is possible as well :(   If the wave guide cover has been damaged, replace it!
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Humming sound and burning smell.
I had the same problem. I replaced the wave guide/cover and everything was fine. It is a piece of cardboard inside the microwave that covers the magnetron. Mine was saturated with grease, and was damaged by the fire. If yours is still intact and not that greasy, You can carefully remove it. Clean both it and the area inside the cavity with an alcohol based cleaner. If there is so much as a pin hole in the cover it will need to be replace. When grease somehow gets behind the cover an arc is formed which causes the problem.
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kbms1454r
Your magnetron is leaking and needs to be replaced.
Oct 29, 2007 | KitchenAid KBMS1454R Microwave Oven
KitchenAid Architect® II KBMS1454S Stainless Steel 1000 Watts Microwave Oven Logo
29 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
