Question about Drills
How to take apart my hilti cf foam gun
The cleaner i put on will only come out in v,small spurts like there is no pressure in the can, or the trigger mechenism is faulty. would appreciate any answers. thank you
david04928
  • 102 Answers
SOURCE: north star petrol pressure washer.
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Posted on Mar 15, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 5603 Answers
SOURCE: Hello there.My Karcher pressure washer motor
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Posted on Oct 03, 2009
  • 33 Answers
SOURCE: Hilti TE6A battery dril 36volts,trigger problems
what about the brushes. even if they arent worn completely down they sometimes will not have enough pressure on the commutator tabs to keep the tool running. if it works better upside down or sideways that is often an indication of faulty brushes. the springs that hold the brushes against the commutator may also be weakened to the point that they don't properly force contact. you may also have burned or blank spots on the commutator/armature.
try new brushes and make sure the associated wires arent broken, pinched or otherwise damaged. also clean the commutator with a polishing cloth or very very very fine sandpaper, being careful not to scratch, groove, or otherwise damage the tabs. also, the bearings that fit in the housing to stabilize the armature may be worn or seizing, which will cause the armature to move erratically and/or bind.
if all of these things have been done, and the problem STILL exists, then probably the motor itself (armature/field) is breaking down. the brushes and bearings at least are probably in stock at a local tool repair shop, and of course all parts can be purchased through hilti.
Posted on Dec 04, 2009
  • 6 Answers
SOURCE: my 360 wireless controllers right trigger button
this is happening because the trigger is not sending a signal to the xbox try searching wrong soldering and fix em
Posted on Dec 19, 2009
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 | Garden
Leaking air behind the trigger
If you take the gun apart you will see a small o-ring on the trigger side that needs replacement and possibly the spring on the media adjuster side as well
Feb 18, 2013 | ANEST IWATA IWA5810 LS400-1302 Spray Gun...
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 | FAIP Garden
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
The handle leaks and seems to not have the tension on the handle. I have it apart and it seems like a tension string is broken but I can't see how it reconnects.
They don't offer parts for the trigger guns, you would just need to purchase a new trigger gun. There is a number of different trigger guns for these machines though, what is the model and part number of the machine that you have?
Oct 10, 2010 | Karcher 2500 PSI Pressure Washer
When I take the trigger apart and then put it back in the same way it then leaks air. I have 4 guns and I have been carefully cleaning them. Each time I take the trigger parts out and clean them and...
I believe that the most popular roofing gun for professionals is the hitachi line of nailers. Hitachi guns are amoung the very few however that actually move the cylinder when fired instead of the headvalve. This is rather odd because it requires more moving parts. Your guns have a trigger pin/plunger (white plastic with small oring part # 878-121) that pushes on a urethane ball. This ball is potential cause of leaks. Make sure that the ball is perfect. Replace as needed. Most leaks around the trigger area are acutally coming from just in front of trigger which is plunger pushed by safety foot. Spray soapy water around trigger area and make sure where air is actually leaking. If leaking from safety foot plunder source of leak is actually orings inside of gun around cylinder. (usually oring part #876-161 that fits on the cylinder plate). Parts and parts lists are at www.toolpartsdirect.com. Good luck with your guns and post again if you have other question.
Jul 29, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
Drills Logo
204 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
