Question about Philips Magnavox 20MS233S 20" TV
The tv will not turn on
At first the screen was flickering for a little while then the picture was regular. the volume would not go up or down. Sometimes unable to turn or on with remote or manually.
I tried unplugging it for 60 seconds to see if it would work but no go
    Genius:
  • Philips Master
  • 1,673 Answers
This can be from problems with the power supply, or with the uPC controller section. It is also possible that there are problems in the control circuit board area.
You would have to take the set to a TV service center to have it properly troubleshooted to find the cause of the failure. For this model you may find that servicing it is not feasible.
Jerry G.
Posted on Jan 10, 2009
Sony bravia sound stuck
For a little more you can get a new better set with warranty. A no brainer.
Mar 21, 2017 | Televison & Video
The problem is a shaky picture with a static line that's vertical when watching regular TV. This problem does not happen when not watching in HD through our Myth TV (DVR). Closed captioning does not...
Regular TV, you mean by the aerial and internal tuner, if it is like that, then it is a problem with the TV tuner board.
If by regular TV you mean an external TV box, then the TV box is faulty or you have a cable or ferquency problem.
Sep 13, 2008 | Televison & Video
Rear projection tv colors flickering
Two types or more of sets: regular TV sets with a picture Tube, big rear projection sets, Plasma, LCD, DLP
A model number would allow me to give you the answer--I suspect you have a set with a picture tube(regular tv)
Let me know which so I can try to give correct answer.
Mar 28, 2012 | Televison & Video
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
Picture flickers on all inputs.
If your having pixelation,try disconnecting other tvs
from the wall.you may have a noise or DB drop off or surge issues.check all splitters from the tube to the soffit of your home.If you find one upside down out side ,water maybe be getting in.Remove all snap adapaptors,screw on only.Splltters are
cheap,,easy way is spend $3 extra a month to have your cable Co repair or replace any seeping cables or adaptors and/or splitters.
Feb 05, 2009 | Toshiba 46HM95 46" HDTV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Philips Magnavox 20MS233S 20" TV Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
