Question about GE Cooktops
Orange flames on gas stove top
We have been getting orange topped flames on our GE gas cooktop JGP389 The gas company agent said he thought it was too high a gas pressure and adjusted the pressure coming into the stovetop which helped for awhile, but now we intermittently get orange flame again. Agent also said it could be a regulatory. What can we do? And if we need help, how do we find someone qualified?
  • A.l. Port Dec 07, 2012
    Turns out the orange flame was due to our ionizer humidifer. After turning the humidifer off for a day, the flames turned blue again. Wish I had known this. The gas company rep was here for hours testing and changing out regulators and such without success. He also tested the CO levels on the orange flame and found it to be at completely acceptable levels. He asked a an older tech, who said it could be the humidifer. Interesting that neither the gas company nor the GE helplines, knew that this was an issue. In fact, the gas company was the one that made us concerned, reacting as if we had yellow flames, which do indicate incomplete combustion and are dangerous. Once you know to check for it, you'll find this information all over the net including: http://www.youtube.com/watch?v=iiP1KcPdQ...
Rotu
  • 175 Answers
SOURCE: gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
Posted on Oct 31, 2006
  • 155 Answers
SOURCE: Pilot Flame is too high.
You will only need to purge air from the supply if this is newly installed or if you have recently disconnected / reconnected the main gas supply for some reason. Otherwise, you can just skip that step.
If you do need to purge the system do the following:
MAKE SURE THE ROOM IS WELL VENTED TO OUTSIDE
REMOVE ALL SOURCES OF POSSIBLE IGNITION
Fully open the largest burner and allow to run until gas is smelt.
There is no way to say exactly how long it needs to be open as this very much depends on the length of pipework feeding the appliance, but in a typical domestic installation, this shouldn't be more than about 5-10 seconds.
Hope this helps,
Matt
Posted on Mar 03, 2008
geemarie
  • 876 Answers
SOURCE: GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Posted on Aug 01, 2008
SOURCE: GE Profile Gas Cooktop, Model JGP975SEKSS
Buy the Burners for my 36" GE Gas cooktop.
Posted on Nov 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Posted on Feb 20, 2009
How do I adjust the flames
What is the gas pressure into the stove? This is a critical measurement and should be done by the gas company.
Dec 24, 2014 | Premier Range. 36 in. Freestanding Gas...
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Hi - I have a 4 burner GE gas cooktop. The clicking sound comes from all the burners but 2 of them are difficult to light. If I hold my hand over the top ... they will light! Is there an adjustment that...
Usually this happens if something has been spilled or a pan overflowed and is partially clogging some of the burner holes. Make sure the burner holes are clear and try poking them with a sewing needle to make sure. I am assuming the flames are a nice blue color and not a lazy yellow or yellow-tipped. If there is some orange, that is usually an indication you are burning off some food and will need to be cleaned. If that doesn't appear to be the issue, then let us know and we'll dig deeper. Douglas
Sep 18, 2010 | GE 30 in. JGP328 Gas Cooktop
Flame in cooktop (3rd one) seems to be mostly blue with orange tips appearing here and there, but is agressive and pots almost burn with food not cooked. No way to turn down on a sealed cooktop. Is this...
if your on propane you will get a little bit of a orange tip. need to see if your model has shutter valves. this adjustes the gas air mixture
Jun 22, 2009 | Cooktops
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Cooktops Logo
74 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
