Question about Royal Adler Powerwriter MD Typewriter Power Writer MD
Correction tape right side won't lock in
Right side of correction tape falls off doesn't lock in. First time I have changed it, ordered new tape now it is worse.
  • Royal Master
  • 3,594 Answers
If you don't have a manual go to NADIST.COM click on current models you will that one of the Nakajimas is the same as your T/W.
DickyO
Posted on Nov 27, 2012
My Dyson falls backward & won't stand up - what's wrong?
Hi Kay,
I'm sorry to hear you're having difficulty with your DC18. If the stabiliser doesn't seem to be locking the machine upright, I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will be useful if you can have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC18 all floors Bagless Upright...
WHEN MAKING A BOTTON HOLE THE RIGHT SIDE SEWS GREAT BUT THE LEFT DOESN''T? WHAT CAN I DO TO CORRECT THIS?
you may have to use a washable stablizer when doing the buttonhole
also check to make sure you have the right needle & the right thread for the fabric
Mar 08, 2012 | Singer 8280 Mechanical Sewing Machine
It's stuck in place and won't move either left or right. When I hit a key it types that letter, but the paper doesn't move to the next space
If it is stuck in the middle of the page it probably has a carriage lock usually just below the carriage on the R. or L. side.
DickyO
Oct 12, 2011 | Olivetti Lettera 35 L Typewriter
2008 chevy impala rear locks only work partially
I have problems with all door locks. Some work some others don't. Or right side of the car won't lock or unlock. Or the left side won't unlock or lock. Or they all work great . When it's very hot outside none will or will.What's the problem.
Sep 09, 2011 | 2008 Chevrolet Impala
I have not received a diagram of my stylus wiring. none of the sites that was recommended have helped. do you know the purpose of each color of the four wires?
One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
Jul 30, 2011 | Audio Players & Recorders
Just changed oil in 2004 Volkswagen jetta. now car won't startled
Are you absolutely sure that you put the right weight oil back in the car? These cars are very sensative to this and if it doesn't see the correct oil pressure it won't start beacause it uses oil pressure to fire the fuel injectors. You need to be using 505.01 oil in your car only. Anything else can cause a no start or major engine damage!
Jul 03, 2011 | 2004 Volkswagen Jetta
The instructions tell me to lift the lid, but I don't know how, it seems to be locked, is there something underneath I need to push or pull. I need to change the ink cartidges
On this particular printer there is no locking mechanism to access the ink cartridges. In order to open the cover, use a single open hand and place your fingers just underneath the screen on the front, and pull upward. The entire scanner piece should raise and a plastic bar on the right-hand side will lower down to prop it open.
If you're having a lot of trouble opening it, you may want to check around the sides of the printer to see if there is any tape leftover from when the printer was packed in its original box. When they ship a printer it is always covered in tape to make sure that nothing falls open or breaks before it's delivered, and there may be a piece of clear (almost invisible!) tape left over preventing the printer from opening.
Once it's open, the ink cartridges should come to the middle. Press down on the small lever on the print head (the ink cartridge holder) to pop the cover open so that you can install the cartridge.
Hope this is helpful!
May 09, 2011 | Lexmark P6350 All-In-One InkJet Printer
Neptune front load will not spin excess water - clothes saturated, will not go to the fast spin that gets majority of water out, if i spin it with my hand manually i can hear what sounds like a significant...
there's a couple of problems that can cause this,take it apart and get to the door latch assy.top center of opening where the door latches.after you remove the front panel leave the door in place,lock the door and put it into spin,check the wax motor to make sure it's pushing all the way over,you can push on it when it stops to see if it didn't move all the way over,when you push on it and if it goes into high spin change the wax motor part number 22002119.next there's a micro switch to the right of the wax motor,if this is bad it won't go into high spin,door lock spin enable switch part number 22002162,you can pull it out,click it in and out and check it with a meter.if it feels funny or not clicking all the time when pushing the plundger in and out replace it.if that feels good theres an inertia switch part number 22003302.you have to remove the right side of the boot to get at this switch.it's on the right side of the tub near the top,it's a little tricky to get at it,the screws that hold it on are 1/4 inch,you can use a nut driver just stick some plumbers putty or permagum in the socket so the screw won't fall out when you remove it and put it back or a magnet head works great.these are the things to check,do them in the order i gave you and hopefully it will be the micro switch,changing out the inertia switch is a little time consuming.remove the screws that hold the door on and remove the other two phillips screws on the other side,pull off the front panel but leave the door in place,once you get into here you'll see how to get to the top door latch parts.here's a video so you can see the parts i'm talking about,you'll see the wax motor and the micro switch,not the switch above the wax motor it's the switch to the right that will cause the washer from going into high spin,if that's good it will be the inertia switch,just remove the right side of the boot to get at it.good luck,just take your time and it will get done.
May 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
I mixed the distributor cables up,so i need the order to correctly connect
If the wires are still in the distributer, AND, if you have a stock intake manifold, the firing order is on the manifold. If it's a V-8, the number 1, 3, 5, & 7 plugs are on the drivers side of the engine. The number 2, 4, 6, & 8 plugs are on the passenger side. The number 1 plug wire can be located by looking at the distributer from the front of the engine and visually looking between the distributer and the number 1 plug. Visualize the distributer as a clock. The number one position should be located between 4 and 5 o'clock and should have the longest wire of those on that side of the distributer.
If the wires have been pulled from the distributer, then, then, remove the rotor cap, turn the engine over slowly until the rotor is pointing to the number 1 plug. Using the firing order on the intake manifold, starting with number 1, replace the wires going clockwise around the distributer.
Apr 09, 2011 | Chevrolet Chevy Cars & Trucks
Royal Adler Powerwriter MD Typewriter Power Writer MD Logo
48 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
