Question about Car APS997A Two-Way Remote Start and Security System
HOW TO PROGRAM A DEI PPN471T REMOTE START - Car APS997A Two-Way Remote Start and Security System
AVITAL CAR REMOTE START PROGRAM
At this point in my life, I don't know what I would do with out my car remote. It should be an auto electrician that installs the system. As for the program, I am not sure. You might need to look further into it.
Elisa Jed ' http://www.stevemacautoelectrics.com.au/services
May 31, 2014 | DEI Python 1400XP Remote Start/Keyless...
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Need to program rpn471t but I don't have a valet button in the car
Hello Lacey,
The only way to program an additionally remote on one of there systems is with a valet button. I would recomend that you contact a local install shop like Best Buy that works with DEI products. They likley will be able to program the remote for you.
Oct 27, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Jan 10, 2011 | DEI Python 1400XP Remote Start/Keyless...
Had to change the battery in my Python Keyless Start/Remote and now it wont work. How do I reprogram it
To program remote:
turn ignition on
press and release programming switch once ( the siren/horn will honk once)
press and hold programming switch
while holding programming switch, press lock button on remote ( the unit will chirp/honk to confirm programming)
turn ignition off
test remote
Oct 07, 2010 | DEI Python 1400XP Remote Start/Keyless...
Remote start will not work after dealer programmed a new key.
Yes you need to reprogram your immobilizer bypasskit and depend the model you have it is the program mode, I sugest you go under the dash and try to find out the bypasskit box wich is a small black box like 2"x3"in. and see what model you have.
Jan 23, 2010 | Directed Dei Valet 561r Remote...
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
Remote went through washer and dryer...Does not work. Does the system have to be rewired or can I just purchase a new remote
you need to purchase a new remote and the program the transmitter to the brain. it is real easy. but make sure that you purchase the same model of transmiter.
Jan 03, 2009 | DEI Python 1400XP Remote Start/Keyless...
Car APS997A Two-Way Remote Start and Security System Logo
47 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
