Question about Car APS997A Two-Way Remote Start and Security System
HOW TO OPERATE A DEI PPN471T REMOTE START - Car APS997A Two-Way Remote Start and Security System
Car dies when I use my remote start and press the lock or unlock button
This is most likely caused by the car's anti-theft system. Most newer cards require a separate module to be installed to override the anti-theft system while the remote start is in use. Otherwise, when the anti-theft system detects an anomaly, it will immobilize the vehicle.
DEI makes a 556H module for this purpose. The link shows the instrall manual for this device.
DEI 556H Module Info
Dec 12, 2013 | 2002 Honda Civic
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Jan 10, 2011 | DEI Python 1400XP Remote Start/Keyless...
Have had a Dei valet 561r remote on my Honda van for several years. Worked flawlessly. Recently, it began working intermittantly. Did not work for several days. Then worked for about a week. Then nothing....
sounds like your car battery was also replace or it die
believe it or not the remote start needs to be reprogram again
find the valet switch, this what you are going to do
make sure ac radio and any other accesorie are off
start the car with the key within 2 seconds or less press and hold the valet swith, and way until the
led turns on and the parking lights on the vehicle flash about 12 seconds
no turn off the car close the door and start the vehicle with the remote good luck
Nov 19, 2010 | Directed Dei Valet 561r Remote...
My DEI Valet system will not operate the door locks. It responds to the remote with lights flashing as normal, but it does not engage or disengage the lock. The Automautic start feature continues to work...
You failed to mention the year/make/model of the vehicle so, I will assume that there existed some sort of door lock/unlock/alarm disarm bypass module in your vehicle that is no longer functioning. There is no simpler fix then either resetting the module or, remove and replace it.
Sep 29, 2010 | DEI Valet Keyless Entry System
Dei automate remote starter 552 for manual gear installation
It can be installed, but is not recommended. If the car was left in gear and the auto start activated the car will lurch forward. A friend of mine, who is an installer, had his WRX jump a curb in a parking lot in land in a ditch. BTW, he "never left his car in gear". It only takes once.
Nov 08, 2009 | Directed Dei Valet 561r Remote...
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
Car APS997A Two-Way Remote Start and Security System Logo
22 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
