Question about Cell Phones
I have a samsung r261 chrono from cricket and i was wondering if anyone can tell me how to fix it. I can take my charger out and it still charges.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Try dialing *228 and updating the prls on it its kinda like a quick reset to the phone so maybe this will go away when you hook it up to charge
Posted on Dec 13, 2012
Break 4 digit code
Try all possible combinations,usually there is a piece of hardware and/orsoftware to interface into whatever it is you want to guess the password on. Such software and or hardware is made/programmed to repeat the process of entering a password while adhering to certain barriers(like 1 try per 5 minutes ect.). Typically hardware/software is made for particular applications according to what your hacking.
Thanks and good luck
Questions? Just ask
Mr.Mike
Mar 23, 2016 | Samsung SCH R261 Chrono Cricket No...
Tip
Will this work on a samsung Myshot II phone I have cricket service and my phone...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Mar 15, 2010 | T-Mobile MDA
How to jailbreak a cricket samsung
Which model phone? There are forums with step by step instructions on how to root and install custom android is on phones.
Jul 02, 2014 | Samsung Page Plus Fully Flashed Sch R261...
Samsung r261 shuts itself off
Pl try resetting it.The procedure is as follows:
  1. Press the Menu softkey > Settings > Phone Settings > Security
  2. Select Security
  3. Enter Lock Code
  4. Note: The default lock code is the last four digits of your mobile phone number
  5. Select Reset Phone
  6. Press Yes
SCH R261 Chrono FAQ List Cricket Samsung
Jun 14, 2014 | Samsung Chrono R261 R 261 Cricket Camera...
Can anyone tell me where is the best place to buy wireless car charger dock for my Samsung galaxy smartphone?
You can try QI wireless car charging doc,i am using one doc.It's really good and i just place my phone into the holder.It's charge automatically and i can receive any call while charging my phone.You can collect the charging doc from amazon store.CHOE wireless charger i am using. you can try it. Thanks.
QI wireless car charger doc for mobile phones
Oct 21, 2013 | Kyocera Wireless Rapid Travel Charger
Charger dont charge battery
The charge maybe faulty, use a multi-meter and check the voltage on the plug on the adapter. The output voltage should be printed on the label on the charger.
Apr 29, 2012 | Samsung For Cricket Indulge Car...
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
Samsung Memoir not charging when Charger plugged in.
Why is'nt my phone charging ? when i plugged it in ,it says battery temperature is too low or two high. I replaced the battery and it tells me the same thing. please help. It is a
Samsung Memoir
Aug 21, 2009 | Cell Phones
Cell Phones Logo
59 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
