Question about Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher
My dishwasher trips out on certain cycles
I have a LS 2020 stainless steel diswasher -Ariston It trips out 3 times on a cycle. I marked the places where the unit trips and re ran it at the end of the cycle, and she tripped out in the excactly the same spot. any ideas? Craig :)
  • Craig McPhail Jun 06, 2007
    I carefully disconnected the element from the dishwasher and ran the cycle, and it went thru without cutting out.
    does this point to the element, or could the solenoid or motor still be the problem...just using process of elimination.
  • Craig McPhail Jun 18, 2007
    I found the problem - it was the element after all.
    It tripped out on the short cycle only once - and up to 5 times on the long cycle.
    I bought the element from Ariston in Melbourne for only 65.00 incl GST which was alot cheaper than 115.00 quoted by Nemans on the Gold Coast!.
  • 883 Answers
Sounds like faulty wiring inside unit. your circuit breaker is detecting an overload current condition...must look inside for wire touching frame. if none found, then wire fault may be inside of a device like motor or solenoid, so check these with ohmeter to ground-each wire (except chassis gnd) must be isolated from ground.
Posted on Jun 05, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Noise on wash cycle
Support - Dishwashers DW80F600UTS/AA ' Samsung ...
www.samsung.com > Home > Support > Dishwashers
Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product ... Yes; Sound Level (dBa) 48 dBa; NSF Certification Yes; Total Number of Cycles 4; Total Number of Wash Options 2 ...Multiple wash arms ensure even water distribution during a cycle. 3 (Upper ...
Oct 01, 2015 | Samsung Dishwashers
How long does a normal cycle take on the following Kitchenaid diswasher. KUD102CRWH1 Mine takes hours. Is this normal?
If the normal cycle is taken hours then the water temperature is not correct. If you have inlet hot water connection, then check the water temperature. If using cold water then the thermostat or heater in the dishwasher is faulty.
Look for items 7 and 12 in this diagram.
Oct 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Ariston LS 2020 dishwasher is tripping mains switch at several points of washing cycles. What's wrong with it?
It probably uses more electrisity than there is avaliable at peak preformance. It is safer to contact an electrician to have him measure the use of electrisity and why there is this sudden use.
Jun 14, 2010 | Washing Machines
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Kud101 diswasher heater element
The dishwasher will heat the water to a temp of aprox 140deg if the heater is not working then the dishwasher will not shut off because it has to heat the water to a point where a thermostat will close during the heating time the dishwasher time stops advancing, also heater is used to heat the air for dry cycle
Sep 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Ariston diswasher trips out as soon as door closed
hi On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Oct 13, 2008 | Ariston Technologies L63SNA Stainless...
Ariston dishwasher
I have the same problem. I found that a termostatic probe switch off the machine, you can disassemble the door and clean the ventilation holes
Aug 31, 2008 | Ariston Technologies Ariston FO98P...
Dishwasher made clicking sound, then CL light, now nuthin'
I had a similar problem. After a $90 service call I was told it was the main electronic panel. The panel costs $180 and installation is $70. No Frigidaire is worth that. You, like I, should buy a new non-Frigidaire.
Aug 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Odor 2 days after cycle
After you have unloaded the the dishwasher, prop the door open with the upper rack out.
Let the inside air out. After a short time the remaining moisture will evaporate. Stainless steel dishwashers are prone to an odor if you do not use the machine daily. There are after market products that are citrus based that will help. Check with Bosch.
Jun 14, 2008 | Bosch Evolution 500 SHE45M06UC Built-in...
Ariston Technologies L63SNA Stainless Steel Built-in Dishwasher Logo
789 people viewed this question
Top Ariston Technologies Dishwashers Experts
Steve Allison
Steve Allison
Evan Benson
Evan Benson
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
