Heil sp80 heater wont turn off. The ignitor is not turning on as to its not heating up. What would cause this problem?
The heater wont quit running. Its just blowing cold air and ignitor seems to not be working Or atleast its not heating up to try and ignite. I tried to see if it was still pushing the gas and ignite it manually and there is no gas coming through either. There is fuel in the tank. just to cover that base. What could be the problem and potential fix.
  • josh Nov 27, 2012
    Thank you all for the suggestions. I stopped at a heating and cooling shop in town today and talked to one of the service reps there. It turned out to be that it had over heated and tripped the limiter. I just pushed the reset button on it cuz i have a manual limiter and it started up without a problem. I also changed the filter cuz well it wasnt pretty. the cause for the overheating im guessing.
jsrock516
  • 5911 Answers
SOURCE: does not heat
There is NO starter on a gas dryer burner assembly. The burner is controlled by gas valve coils and a glow bar igniter. Once the igniter reaches the appropriate current level, the gas valves open and you have ignition. The common problem is a weak igniter. You need to do a current measurement to make sure the igniter is within tolerance. If it is within specs, then I would agree with docjohn174 about replacing the coils. If its not within specs, you need to replace the igniter. Depending on the type of igniter you have, the current rating is as follows:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
I still need an accurate model number in order to confirm WHICH type of igniter you have.
Posted on Oct 07, 2008
SOURCE: heater blows cold air
I solve the problem the vacum line was unhook on the passenger side under the glove box
Posted on Oct 23, 2008
tbugger
  • 232 Answers
SOURCE: REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Posted on Dec 16, 2008
tinytrees
  • 92 Answers
SOURCE: pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Posted on Feb 03, 2009
steve_lima
  • 181 Answers
SOURCE: Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Posted on Feb 23, 2009
I have a 2007 mule does the fuel pump have to be a certain pressure aftermarket one works good for a bit but then starves for fuel back off throttle and picks back up
stock fuel pump only runs at 3-4psi and only runs on demand. stops when pressure is meet. You can test it by unhooking the line goin to the carbs and flow it into a container. It wont run till you try to start the bike. also if you turn the fuel off and let the bike run, as soon as the fuel in the bowls goes down you can hear/feel the pump clicking trying to build press.
Dec 28, 2017 | Dryers
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
Heil heater keeps turning on and then shutting right off. Reset interior and exterior breakers to no avail. When the unit will kick on heat does come from vents
How long do burners stay on? If they go out within a few seconds, the flame sensor may need to be cleaned. The control board you have shown is probably doing it's job by shutting down and something else is causing this. Always check your air filter first. More info needed.
Jan 11, 2010 | Honeywell International Heil Quaker...
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
